MMM-WatchDog
12 Posts 7 Posters 11.2k Views 6 Watching
    MichMich Admin
    This MagicMirror² module keeps an eye on your UI and quits app in case the UI crashes. If you combine this with the PM2 process manager, MM2 will automaticly restart after a UI failure.
    [card:MichMich/MMM-WatchDog]
    1 Reply Last reply Reply Quote 5
      EXCELLENT!! Thank you!
        paviro Admin
        Maybe this should be a default module?
        – The Doctor
          MichMich Admin
          In most cases this module should not be necessary and probably only causes confusion. I built it for a mirror running on macOS which gives some issues due to an webGL module which causes a buffer overflow after a few days of running. (Bug in WebGL).
          So this module is only there for edge cases. In most cases we just need to hunt down the bug causing the UI issue.
          P 1 Reply Last reply Oct 4, 2016, 5:16 PM Reply Quote 0
            paviro Admin @MichMich
            @MichMich ah I see :)
            – The Doctor
            • K Offline
              KirAsh4 Moderator
              macOS is the edge case. :)
                Mr.Meeseeks
                Does it work on server only mode?
                CAAAAN DOO!👍
                  MichMich Admin
                  In that case only the server will be restarted, so that doesn’t make sense.
                    Mr.Meeseeks
                    Ha, ya that’s what I saw, it would shut down server. so I guess another reason why it’s not a default module unless it could detect if running in server mode.
                    CAAAAN DOO!👍
                    • F Offline
                      fox
                      Are there any issues with the newest update known?
                      I got it work again after removed the watchdog module
                      Issues With MMM-WatchDog known?
                      https://forum.magicmirror.builders/post/29827
                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
