    MMM-WatchDog
    12 Posts 7 Posters 12.4k Views 6 Watching
    • MichMichM Offline
      MichMich
      In most cases this module should not be necessary and probably only causes confusion. I built it for a mirror running on macOS which gives some issues due to an webGL module which causes a buffer overflow after a few days of running. (Bug in WebGL).
      So this module is only there for edge cases. In most cases we just need to hunt down the bug causing the UI issue.
      paviroP 1 Reply Last reply Reply Quote 0
      • paviroP Offline
        paviro @MichMich
        @MichMich ah I see :)
        – The Doctor
        • KirAsh4K Offline
          KirAsh4 Moderator
          macOS is the edge case. :)
          • Mr.MeeseeksM Offline
            Mr.Meeseeks
            Does it work on server only mode?
            CAAAAN DOO!👍
            • MichMichM Offline
              MichMich
              In that case only the server will be restarted, so that doesn’t make sense.
                Mr.Meeseeks
                Ha, ya that’s what I saw, it would shut down server. so I guess another reason why it’s not a default module unless it could detect if running in server mode.
                CAAAAN DOO!👍
                • foxF Offline
                  fox
                  Are there any issues with the newest update known?
                  I got it work again after removed the watchdog module
                  Issues With MMM-WatchDog known?
                  https://forum.magicmirror.builders/post/29827
                  Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                    rak
                    Hello guys,
                    I have mm running via PM2 already. I installed MMM-Watchdog. The gui crashed this night, but it did not restart. What did I do wrong?
                    My PM2 looks like this …
                    $ pm2 info MagicMirror
                     Describing process with id 0 - name MagicMirror
                    │ status            │ online                                   │
                    │ name              │ MagicMirror                              │
                    │ restarts          │ 0                                        │
                    │ uptime            │ 37m                                      │
                    │ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
                    │ script args       │ N/A                                      │
                    │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
                    │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
                    │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
                    │ interpreter       │ bash                                     │
                    │ interpreter args  │ N/A                                      │
                    │ script id         │ 0                                        │
                    │ exec cwd          │ /home/pi                                 │
                    │ exec mode         │ fork_mode                                │
                    │ node.js version   │ N/A                                      │
                    │ node env          │ N/A                                      │
                    │ watch & reload    │ ✔                                        │
                    │ unstable restarts │ 0                                        │
                    │ created at        │ 2018-09-09T08:36:00.617Z                 │
                     Revision control metadata
                    │ revision control │ git                                            │
                    │ remote url       │ https://github.com/MichMich/MagicMirror.git    │
                    │ repository root  │ /home/pi/MagicMirror                           │
                    │ last update      │ 2018-09-07T00:04:31.656Z                       │
                    │ revision         │ 6aa156d95667b230264fd99c5df877b25759e710       │
                    │ comment          │ Merge pull request #1343 from MichMich/develop │
                    │ branch           │ master                                         │
                      rak
                      Found this. Can this b the reason it did not restart again?
                      When your app stays up for less than min_uptime (1s by default) until max_restarts (15 by default) is exceeded, it will stop restarting. So the most likely explanation here is that your app keeps crashing over and over for some reason. Whenever it stays up for longer than min_uptime, max_restarts is reset, so the default values should work just fine.
