    Facial Recognition Module - Step by Step Guide
    28 Posts 14 Posters 37.2k Views 22 Watching
      sdetweil @OGElijah
      @ogelijah u have to edit the failing py script
      and change the failing line
      O 1 Reply Last reply Reply Quote 1
      • O Offline
        OGElijah @sdetweil
        @sdetweil I get you! I was being an idiot and I went into the wrong script. But now I’ve reached the point where it says “no module named cv2”
          sdetweil @OGElijah
          @ogelijah no idea. that’s a python lib, which should have been installed from the prior setup steps
          • O Offline
            OGElijah @sdetweil
            @sdetweil Ah, okay. I’ll keep on working on this. Cheers
              sdetweil @OGElijah
              @ogelijah because you replaced a line that used cv2, with another line that used cv2
                mraeymaekers @sdetweil
                This fix worked! Thank you.
                My error message:
                python capture.py
                Traceback (most recent call last):
                File “capture.py”, line 18, in
                import lib.capture as capture
                File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py”, line 21, in
                from . import config
                File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py”, line 15, in
                (CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.version.split(“.”)
                ValueError: need more than 3 values to unpack
                Steps to fix:
                cd ~/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/
                nano config.py
                go to line 15 … I commented out the original line and added a line with ‘,mv2’ removed.
                #(CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.version.split(“.”)
                (CV_MAJOR_VER, CV_MINOR_VER, mv1) = cv2.version.split(“.”)
                • O Offline
                  OGElijah
                  I can’t get the .xml file no matter how hard I try… I keep running the train.py file and wait, but nothing happens
                    sdetweil @OGElijah
                    @ogelijah how many images do you have for different people,?
                    what pi is this?
