How can I show a borderless (Bash) shell terminal window on top of MM?
xtermshellbashterminalconsole
3 Posts 2 Posters 2.2k Views 2 Watching
  • E Offline
    E3V3A
    Hello!
    I would like to show a borderless (Bash) shell terminal window on top of MM.
    At first I thought I’d have not make an entire new MMM, but then realized it would have to
    involve a lot coding in JS and integration of xterm.js etc etc. which would be crazy, compared to just showing a terminal “on top” of MM. (Coping sdout to MMM iFrame wouldn’t do it since, I need the colored xterm with terminal graphics.)
    However, I would like the appeatrance to be controlled or activated by some MMM module.
    How would I best go about this?
    Or perhaps there’s already an MMM-xterm somewhere?
    "Everything I do (here) is for free – altruism is the way!"
    MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
    N 1 Reply Last reply Jan 23, 2018, 1:51 PM Reply Quote 0
    • N Offline
      ninjabreadman @E3V3A
      @E3V3A You can experiment with urxvt and with URxvt*borderLess:true in .Xdefaults. You can then use ChildProcess.exec() (primer here) to launch urxvt which should also permit you to kill it from MM.
      Problem with config or JavaScript? Copy/paste it into JSHint.
      Check out the detailed walkthroughs on install, config, modules, etc.
      E 1 Reply Last reply Feb 19, 2018, 1:55 PM Reply Quote 0
      • E Offline
        E3V3A @ninjabreadman
        @ninjabreadman Hi! Thanks, I knew about that, but was hoping to use the default lxterminal, but unfortunately it only allows --geometry=CHARACTERSxLINES as option.
        Your solution of using rxvt-unicode seem pretty good as it supports 256 colors etc. However, in the end, I decided that I’d rather have a native MMM, than just throwing a window on top of everything. That complicates things though. I simply don’t see how to go about implementing the JS version of xterm into a Module. Perhaps something to suggest in the requests area?
        Anyway, could be useful for all those people and command-line junkies, who want to see their raw python output.
