    Thin, Frameless Mirror
    17 Posts 8 Posters 32.5k Views 10 Watching
      Diddern @Bangee
      @Bangee not atm, but I might end up cleaning and moving the rpi’s location later this summer, and then i can take some pictures for you ;)
      • ? Offline
        A Former User @Diddern
        @Diddern Thanks! As for affixing it to the wall, where did you get the cap portion? It appears that it is a bolt that goes through the glass, then through the spacer and into the wall, correct? Again, fantastic design.
          Diddern @Guest
          @mizzoudavis the caps where bought at the glass-cutters. It’s a threaded plate that the screw goes throug. Kindof formed like a thik coin with threads on. The end cap is then screwed on to it with the mirror in between the spacers and the cap-plate.
          This can make it little difficult to unmount the mirror, but it looks good, so the extra 2 minutes when doing maintenance is worth it.
          • ? Offline
            @Diddern Ahh. So something like this? http://www.displays2go.com/P-9681/Standoffs-Economy?utm_source=google.pla&utm_medium=cpc&utm_campaign=GooglePLA&gclid=Cj0KCQjwwLHLBRDEARIsAN1A1Q6xEeodRvTWGlg8XI-CFBCXnaApdb26bdN2hd9XPM_Hme26Pts5tKMaAjn_EALw_wcB
            Thanks!
              Diddern @Guest
              @mizzoudavis almost! The one i use is more like this, but that was because of the custom spacers. Another option would be edge mounted spacers. I think they look really nice. Some US/UK-companies make them to length
              • F Offline
                freel132
                I have problem covering area around screen. Tryed to use black film, but bubbles poping up. What material you used? Please drop me link from amazon. Thx
                • K Offline
                  kakemanx
                  Did You ever finish the Yr.no module? :)
                  Any other usefull norwegian modules?
