    MMM-PIR-Sensor: "Welcome back" message
    2 Posts 2 Posters 2.3k Views 2 Watching
    • D
      deWizard
      Hi there,
      I’m completely new to all of this but still want to give it a try.
      I’ve intergrated the MMM-PIR-Sensor module to my MagicMirror and it’s working just fine.
      The Issue I’m now facing is that I want to display a “Welcome back!” message when the monitor is reactivated. I’ve tried some things but none of them worked at all.
      Anyone to help me out with that - it would be very appreciated. :)
      • D
        doubleT Module Developer
        I don’t have a PIR to test, but looking at the code, I’d suggest trying something like this:
        You need a DOM element to show the message in. You can borrow it from the default module helloworld and modify it:
        getDom: function() {
            wrapper.setAttribute("id", "welcome-message");
            wrapper.innerHTML = "";
            return wrapper;
        And then, based on self.sendSocketNotification("USER_PRESENCE", true); in the node_helper.js you add
        this to the MMM-PIR-Sensor.js :
            if (notification === "USER_PRESENCE"){
                this.sendNotification(notification, payload)
        //  new:
                if (payload === true) {
                document.getElementById("welcome-message").innerHTML = "Welcome back!";
                setTimeout(() => {
                    this.removeMessage();
                }, (1*60*1000); // = 60 seconds
        removeMessage: function(payload) {
            document.getElementById("welcome-message").innerHTML = "";
        If you use it like this, the message is only shown for 1 * 60 * 1000 miliseconds = 60 seconds (set as desired) and then removed.
        This is all untested but hopefully gives you some clues where to look and work on the code.
        Reply Quote 3
