    [MMM-Roomba980] - Live Roomba Stats
    12 Posts 4 Posters 7.4k Views 4 Watching
      relm923
      Description
      Display basic stats from any Wi-fi enabled Roomba on your local network
      • Name
      • Job Status
      • Bin Status
      • Battery Charge
      Supports English and Spanish
      Screenshot
      screenshot
      Let me know what you think and if you have any ideas enhancements!
      Download
      [card:relm923/MMM-Roomba980]
        joseska
        Great… I´m starting with my magicmirror, but when are ok I will try to create similar module for xiaomi vacuum.
        maybe with your module and this “https://github.com/seikan/homebridge-xiaomi-mi-robot-vacuum” I will create a Frankestein with my low level coding ;)
        Thanks…
        sorry for my english, I´m Spanish…
          djsunrise19
          Cool :). Seems to be compatible with more than one romba(980)?!
          Compatible robots: all 800 and 900 series with HOME app.
            relm923 @joseska
            @joseska Looks like that should work. Let me know if I can help
            J 2 Replies Last reply Reply Quote 0
              relm923 @djsunrise19
              @djsunrise19 Good catch! I renamed the repo/package to MMM-Roomba to reflect the compatibility. The old links should still continue to work
                joseska @relm923
                @relm923 Thanks… my nodejs coding is very bad.
                I´m trying with MIIO API for xiaomi vaccum data but sometimes work and others not work…
                I´m trying…
                thanks…
                  joseska @relm923
                  @relm923
                  Hey… Can you help me… the module always is “LOADING”.
                  for Now the data is trought json url because miio not work property. JSON work well, but the module always is “LOADING”. not work
                  the url of the module is: https://github.com/joseska/MMM-Xiaomi-Vacuum
                  sorry, is a copy-paste of your module, for now I have not been able to put the credits on github…
                  thanks…
                  R 1 Reply Last reply Reply Quote -1
                    relm923 @joseska
                    @joseska I’m not familiar with the Miio/Xiaomi API.
                    Are you seeing data returned from the raw HTTP request (looks like you’re logging some)? If you are, you’ll need to call self.sendSocketNotification('STATS', self.stats); after updating self.stats to tell your module to update. Unfortunately I can’t test anything since I don’t have a Xiaomi.
                    You may want to look at using https://github.com/aholstenson/miio too.
                      joseska @relm923
                      This post is deleted!
                        joseska @relm923
                        @relm923 Hi… WORK… ;)
                        the error was that I rename renderPhase function to renderPhase2. (Novice)
                        I need to change some things still and use miio to get vacuum data, but for now WORK…
                        When use miio to get data I upload to github and publish here If you give me permission to use your module as the base of mine…
                        thanks for your time…
                          relm923 @joseska
                          @joseska Nice work! Feel free to use my module how ever you want
                            Baschti
                            I got the whole time only “loading” on my screen! I Installed Dorita980 und the module! Did you have some hints?
