[MMM-Roomba980] - Live Roomba Stats
12 Posts 4 Posters 6.5k Views 4 Watching
    relm923
    Description
    Display basic stats from any Wi-fi enabled Roomba on your local network
    • Name
    • Job Status
    • Bin Status
    • Battery Charge
    Supports English and Spanish
    Screenshot
    screenshot
    Let me know what you think and if you have any ideas enhancements!
    Download
    [card:relm923/MMM-Roomba980]
      joseska
      Great… I´m starting with my magicmirror, but when are ok I will try to create similar module for xiaomi vacuum.
      maybe with your module and this “https://github.com/seikan/homebridge-xiaomi-mi-robot-vacuum” I will create a Frankestein with my low level coding ;)
      Thanks…
      sorry for my english, I´m Spanish…
      R 1 Reply Last reply Feb 24, 2018, 1:41 PM Reply Quote 0
        djsunrise19
        Cool :). Seems to be compatible with more than one romba(980)?!
        Compatible robots: all 800 and 900 series with HOME app.
        R 1 Reply Last reply Feb 24, 2018, 1:54 PM Reply Quote 0
          relm923 @joseska
          @joseska Looks like that should work. Let me know if I can help
          J 2 Replies Last reply Mar 2, 2018, 1:00 PM Reply Quote 0
            relm923 @djsunrise19
            @djsunrise19 Good catch! I renamed the repo/package to MMM-Roomba to reflect the compatibility. The old links should still continue to work
              joseska @relm923
              @relm923 Thanks… my nodejs coding is very bad.
              I´m trying with MIIO API for xiaomi vaccum data but sometimes work and others not work…
              I´m trying…
              thanks…
                joseska @relm923
                @relm923
                Hey… Can you help me… the module always is “LOADING”.
                for Now the data is trought json url because miio not work property. JSON work well, but the module always is “LOADING”. not work
                the url of the module is: https://github.com/joseska/MMM-Xiaomi-Vacuum
                sorry, is a copy-paste of your module, for now I have not been able to put the credits on github…
                thanks…
                R 1 Reply Last reply Mar 6, 2018, 10:58 PM Reply Quote -1
                  relm923 @joseska
                  @joseska I’m not familiar with the Miio/Xiaomi API.
                  Are you seeing data returned from the raw HTTP request (looks like you’re logging some)? If you are, you’ll need to call self.sendSocketNotification('STATS', self.stats); after updating self.stats to tell your module to update. Unfortunately I can’t test anything since I don’t have a Xiaomi.
                  You may want to look at using https://github.com/aholstenson/miio too.
                  J 2 Replies Last reply Mar 7, 2018, 12:31 PM Reply Quote 0
                    joseska @relm923
                      joseska @relm923
                      @relm923 Hi… WORK… ;)
                      the error was that I rename renderPhase function to renderPhase2. (Novice)
                      I need to change some things still and use miio to get vacuum data, but for now WORK…
                      When use miio to get data I upload to github and publish here If you give me permission to use your module as the base of mine…
                      thanks for your time…
                      R 1 Reply Last reply Mar 7, 2018, 4:28 PM Reply Quote 0
