    Samsung p2450 with touch border / removing case possible?
    samsung touch case
    5 Posts 2 Posters 2.4k Views 2 Watching
    • E
      eckonator
      Hi, i am new here and i try to build my first magic mirror.
      I bought a cheap 24“ Display from samsung. The model is p2450. It will delivered tomorrow. After i bought the Display, i did a little research and found out, that the Buttons from this Display are by touch on display border (no mechanical buttons). The question is, if the display will work when i remove the case to save place for my mirror?
      Hope someone have a samsung display, too and can answer my question?
      P 1 Reply Last reply
      • P
        Peter @eckonator
        @eckonator I have a 22 inch Samsung with touch panel.
        While removing the plastic rim, I cut out the part with the touch panel and glued it later on the back of the screen.
        Works well!
        Peter
        • E
          eckonator
          Hi @Peter,
          thanks for your help. Have you maybe a photo from your cutted border? What did you use to cut the plastic?
          Thanks eckonator
          • P
            Peter
            I will try to send a photo later.
            I used a metal sawblade.
            It was rather easy to do and the touch still works well.
            Peter
            • P
              Peter
              Uploading a photo is impossible for some reason.
              Can I mail you a photo?
              Peter
