PIR gives black screen
I added a PIR to my MM, and I get a black screen, and no MM in browser on other LAN devices.
Hitting the ‘Windows’ key brings up the Pi start menu, where I can lunch terminal and stop MM.
A simple test script confirms the PIR device is working correctly without MM running.Any ideas on how to fix this, please?
Here are the errors, and my config.
{ Error: Cannot find module 'onoff' at Module._resolveFilename (module.js:455:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._load (module.js:403:25) at Module.require (module.js:483:17) at require (internal/module.js:20:19) at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:11:14) at Module._compile (module.js:556:32) at Object.Module._extensions..js (module.js:565:10) at Module.load (module.js:473:32) at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }Config:
{ module: 'MMM-PIR-Sensor', config: { sensorPIN:22, powerSaving: true, relayPIN: false, powerSavingDelay: 0, relayOnState: 1 // See 'Configuration options' for more information. } }, -
After running
git clone https://github.com/paviro/MMM-PIR-Sensor.gitin~/MagicMirror/modules, did you runcd MMM-PIR-Sensor npm install? The
npm installin this directory should have installedonoffas a dependency. -
That seems to have fixed it, thank you.
There’s now a prompt at the top of MM saying there’s an update available for the PIR module.
How do I go about updating an individual module? -
In your example:
cd ~/MagicMirror/modules/MMM-PIR-Sensor git pull npm installSo you enter the modules directory, tell git to retrieve (= pull) the latest code from github and afterwards you install dependencies again, just in case
Perfect, thank you! :)
