    PIR gives black screen
    5 Posts 2 Posters 2.7k Views 2 Watching
      Richard238
      I added a PIR to my MM, and I get a black screen, and no MM in browser on other LAN devices.
      Hitting the ‘Windows’ key brings up the Pi start menu, where I can lunch terminal and stop MM.
      A simple test script confirms the PIR device is working correctly without MM running.
      Any ideas on how to fix this, please?
      Here are the errors, and my config.
      { Error: Cannot find module 'onoff'
          at Module._resolveFilename (module.js:455:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:403:25)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:11:14)
          at Module._compile (module.js:556:32)
          at Object.Module._extensions..js (module.js:565:10)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
      Config:
      		module: 'MMM-PIR-Sensor',
      				sensorPIN:22,
                      powerSaving: true,
                      relayPIN: false,
      				powerSavingDelay: 0,
                      relayOnState: 1
      • yawnsY Offline
        yawns Moderator
        After running git clone https://github.com/paviro/MMM-PIR-Sensor.git in ~/MagicMirror/modules, did you run
        cd MMM-PIR-Sensor
        npm install
        ? The npm install in this directory should have installed onoff as a dependency.
          Richard238
          That seems to have fixed it, thank you.
          There’s now a prompt at the top of MM saying there’s an update available for the PIR module.
          How do I go about updating an individual module?
          • yawnsY Offline
            yawns Moderator
            In your example:
            cd ~/MagicMirror/modules/MMM-PIR-Sensor
            git pull
            npm install
            So you enter the modules directory, tell git to retrieve (= pull) the latest code from github and afterwards you install dependencies again, just in case
              Richard238
              Perfect, thank you! :)
