    MMM-Google Assistant
    1 Posts 1 Posters 1.9k Views 2 Watching
    • ChrisC Offline
      Chris
      Hello,
      I am trying to install this module but I am having problems with a step of the installation of the Google Assistant SDK.
      (https://developers.google.com/assistant/sdk/guides/library/python/embed/register-device)
      Everything is fine until the step “Register the Device Model”.
      Indeed, when I use the registration tool, it does not work.
      I tried the command:
      (env) $ googlesamples-assistant-devicetool register-model --manufacturer "Assistant SDK developer" \
                --product-name "Assistant SDK light" --type LIGHT --model my-project-1505046981535-my-model1
      Each time I have the following error message:
      Error: Error loading client secret: [Errno 2] No such file or directory: 'client_secret_xxxxx-m88slnqk24bqul282n0nnogs10sck6qo.apps.googleusercontent.com.json'.
      Run the device tool with --client-secrets or --project-id option.
      Or copy the client_secret_xxx-xxxx.apps.googleusercontent.com.json file in the current directory.
      Could someone tell me the procedure to follow?
      Thank you in advance,
      Regards,
