Any MMM-Hive Users that can help, please?
Had the same issue then restarted rpi then suddenly it appeared
Thank you so much…
Thanks so much… I deleted then re-installed, and it works Top man!
Now… how do I set lowest Temp for outside so anything higher than my setting will color the thermoeter icon like your example?
I know the inside will show red as its heating, then go grey when target reached, but unsure how to adjust outside the same way?
@Damian Hi, glad that it’s now working. I’m still going to work on it when I can, but at least no urgency now
For the outside temperature thermometer, check the readme on the github page (https://github.com/flick116/MMM-Hive), specifically the following settings:
highestTemp - Set the highest temperature value, which when reached will use the ‘full thermometer’ icon, plus turn the icon red
highTemp - Set the high temperature value, which when reached will use the ‘three quarters full thermometer’ icon
lowTemp - Set the low temperature value, which when reached will use the ‘half full thermometer’ icon
lowestTemp - Set the lowest temperature value, which when reached will use the ‘quarter full thermometer’ icon
(anything below this temperature will use the ‘empty thermometer’ icon)Only when the temperature equals or is greater than the highestTemp value will the icon turn red.
Ahhhh… thanks.
I thought these referred to the inside temp? I will have another look at the config and see, but off hand I recall only 1 set? Those I thought were for inside… but will look more closely 2mor and play about.So yeah, very happy to have it actually working now, and that the link I gave you helped finding that BG changed things… and other MMM-Hive users on here will also appreciate the work you done to fix it.
Thanks again…
