    MMM-Rest & pimatic REST-API
    1 Posts 1 Posters 867 Views 1 Watching
    • ? Offline
      [[global:former-user]]
      I need help by my pimatic integration with the MMM-Rest Module.
      In the Module docu the url returns a single Integer but my pimatic api returs a string with more informations. like this
      curl http://user:user@himbeere/api/variables/dht-01.temperature
      {“variable”:{“name”:“dht-01.temperature”,“readonly”:true,“type”:“attribute”,“value”:20,“unit”:“°C”},“success”:true}
      what i need ist the value 20
      how i can filter the response?
      i have found this for an php request but i dont know how i can use it in the node_helper.js
      <b>Single value from weather.temperature:</b><br />
      php
         $curl = curl_init();
         curl_setopt ($curl, CURLOPT_URL, "http://demo:demo@demo.pimatic.org/api/variables/variable-set.temperature");
         curl_setopt ($curl, CURLOPT_RETURNTRANSFER, 1);
         $result = curl_exec ($curl);// curl to a variable
          curl_close ($curl);
      	$result = json_decode($result, true);// decode to associative array
      	$result = $result['variable']['value'];//pick desired value
      	print "Temperature: ".$result;
      $result = Temperature 11.4
      node_helper.js
      /* Magic Mirror
       * Module: MMM-Rest
       * By Dirk Melchers
       * MIT Licensed.
      var NodeHelper = require('node_helper');
      var request = require('request');
          start: function () {
              console.log(this.name + ' helper started ...');
              if (notification === 'MMM_REST_REQUEST') {
                  var that = this;
                  request({
                      url: payload.url,
                      method: 'GET'
                  }, function(error, response, body) {
                      // console.log("MMM_REST response:");
                      if (!error && response.statusCode == 200) {
                          // console.log("send notification: "+payload.id);
                          that.sendSocketNotification('MMM_REST_RESPONSE', {
                              data: response
      does anyone have an idea how i can integrate the decode in the node_helper.js?
