    camera or voicecontrol module had a problem. can anyone help me?
    1 Posts 1 Posters 910 Views 1 Watching
    • A
      ahnim
      hello, i am a MM user. and i am using camera and voicecontrol module.
      i wanted to run my Magic Mirror, but it had problem.
      the error says,
      initializing nodemailer
      ALSA lib pcm_dmix.c:1052:(snd_pcm_dmix_open) unable to open slave
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
      ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
      ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
      ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa
      Cannot connect to server socket err = No such file or directory
      Cannot connect to server request channel
      jack server is not running or cannot be started
      JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
      i really thank you for your advice.
