    MMM-RMV "Loading data"
    15 Posts 2 Posters 7.1k Views 2 Watching
    • C Offline
      CvG
      Hy Everyone,
      i have troubles with the MMM-RMV module. I do have an api-key and can make querries with the url so I know my api-key is working.
      But when i setup my module the onyl thing i get is RMV as the headline and “Loading Data” below it.
      Does anyone ever got this thing working?
      Is it possible to post you module config here?
      Here is mine:
                      {       module: 'MMM-RMV',
                              position: 'center',
                                      apikey: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
                                      stationId: '3025547',
                                      fDestination1: 'Mainz Universität',
      • Y Offline
        yawns Moderator
        Does it work with default stationid and destination?
        • C Offline
          CvG
          No, it is not working with any value.
          • Y Offline
            yawns Moderator
            Interesting. I requested an API key to test it
            • C Offline
              CvG
              it still doesn’t work but I have tried something. I disabled every module but MMM-RMV and when I start npm directly I get an Error.
              Error: No connection data recieved. Error code 400
              • Y Offline
                yawns Moderator @CvG
                @CvG
                Would you mind sharing your api key via chat with me? I still did not receive any feedback from the vendor
                Update: just received my api key
                • C Offline
                  CvG
                  Thanks for you support. There ist an solved issue at the github page that might help you. The open one is mine.
                  https://github.com/Com-Lum/MMM-RMV/issues/6
                  • Y Offline
                    yawns Moderator
                    Interesting. Using this does show connections for me:
                                            position: 'top_left',
                                                    stationId: '3000001',
                    Using your config fails for me, debug console shows an error.
                    I hope I find some time tomorrow to dig into this.
                    • C Offline
                      CvG
                      Hmmmmmmmmm?
                      That is strange. I’ll check this when I’m back in my office at monday.
                      "… shows an error. ", means “loading data” in gui and error 400 or do you get something new?
                      When I use my browser to querry the information it works fine. So the data is available for this station.
                      Do you know a way to show the url the magicmirror backend uses? This is where my Linux knowlege ends.
                      • Y Offline
                        @CvG
                        In node_helper.js you find //console.log(some thing with url)
                        Remove the // and restart your mirror. You will see the url in terminal, not browser
                        • C Offline
                          CvG
                          Hello,
                          now its working.
                          My fault was that I misspelled the entry apiKey (I wrote it apikey. With a small k). I found out about this when I displayed the url because the accessId was empty. Now, with a capital letter K it works.
                          Thanks for this and you help
                          • Y Offline
                            yawns Moderator
                            bummer. I didn’t notice that o.O
                            • C Offline
                              CvG
                              The “mean” thing is that your relay has the error too, but you wrote that it workes for you.
                              • Y Offline
                                @CvG That’s because I tested on one machine and responded on another. I copied your config (and therefore your error) and just modified with my stationID.
                                • C Offline
                                  CvG
                                  Hello,
                                  yes, I assumed that but finaly you led me to the right solution.
