    Improve updatenotification module (to be module selective)
    5 Posts 2 Posters 2.1k Views 2 Watching
    • E Offline
      E3V3A
      I would like to see the default updatenotification module to allow us to control what modules to show for updates.
      Currently:
      I keep getting notifications for minor updates to certain modules that I do not intend to update. This is annoying, as I do not wish to disable the updatenotification module, since it is very useful for other core modules.
      It would be great to have a simpler way to select what modules we either do want or do not want to see updates from. Perhaps through an additional module option, like moduleUpdateBlacklist: [MMM-myModdedModule, MMM-CryptoCurrency]?
      I guess a workaround could be to remove the .git directory in the modules home directory, but then you remove all git features for that, which is just dumb.
      Any ideas out there?
      "Everything I do (here) is for free – altruism is the way!"
      MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
      • E Offline
        E3V3A
        Ok, this is the idea.
        We add the blacklist config option list to the module.
        When a module present in the list, the updatenotification module will rename that modules .git to .git_disabled. Tada’! No more messages…I think.
        • N Offline
          ninjabreadman @E3V3A
          @E3V3A But also means you lose the metadata stored in .git to manage (incl. update later) via .git without renaming the folder.
          Why not have updatenotification iterate over/skip modules on the blacklist? Something like changing this line in node_helper.js:
          if (defaultModules.indexOf(moduleName) < 0) {
          To the following?
          if (defaultModules.indexOf(moduleName) < 0 &&
          this.config.ignoreModules.indexOf(moduleName) < 0){
          This means if the module is either (1) in defaultModules or (2) in the (new) ignoreModules it gets skipped.
          Remember to also add ignoreModules: [] to defaults in updatenotification. You can then avoid altering the filesystem whatsoever.
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
          N 1 Reply Last reply Reply Quote 1
          • N Offline
            ninjabreadman @ninjabreadman
            Although I concede I’m not sure how to set the config parameters for updatenotification in config.js (whether you can set params without instantiating the module).
            • E Offline
              E3V3A
              Ah Yeah. That actually sound like a much better solution!
              Not sure when I’m gonna have time to implement it though. Kinda low on my priority list, right now. We’ll see…
