    Dependency Issue
    1 Posts 1 Posters 930 Views 1 Watching
    • M
      mirrX
      Hi there, I have the following issue after installing the software.
      Here is the console output:
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: binary-extensions@^1.0.0 (node_modules/is-binary-path/node_modules/binary-extensions):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Failed to parse json
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: No data, empty input at 1:1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ^
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File: /home/pi/.npm/binary-extensions/1.11.0/package/package.json
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: y18n@^3.2.0 (node_modules/yargs/node_modules/y18n):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File: /home/pi/.npm/y18n/3.2.1/package/package.json
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: cliui@^3.0.3 (node_modules/yargs/node_modules/cliui):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File: /home/pi/.npm/cliui/3.2.0/package/package.json
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: window-size@^0.1.4 (node_modules/yargs/node_modules/window-size):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File: /home/pi/.npm/window-size/0.1.4/package/package.json
      npm ERR! Linux 4.9.35-v7+
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! node v6.13.1
      npm ERR! npm  v3.10.10
      npm ERR! file /home/pi/.npm/os-locale/1.4.0/package/package.json
      npm ERR! code EJSONPARSE
      npm ERR! Failed to parse json
      npm ERR! No data, empty input at 1:1
      npm ERR!
      npm ERR! ^
      npm ERR! File: /home/pi/.npm/os-locale/1.4.0/package/package.json
      npm ERR! Failed to parse package.json data.
      npm ERR! package.json must be actual JSON, not just JavaScript.
      npm ERR!
      npm ERR! This is not a bug in npm.
      npm ERR! Tell the package author to fix their package.json file. JSON.parse
      npm ERR!     /home/pi/MagicMirror/vendor/npm-debug.log
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.2.2 install: `cd vendor && npm install`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.2.2 install script 'cd vendor && npm install'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     cd vendor && npm install
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      Even after I change the config.sample into config.js the software starts, but it shows only a blank screen.
