    MMM-Domiticz
    68 Posts 18 Posters 49.0k Views 18 Watching
    • C Offline
      Charley Module Developer
      @peter
      I am sorry this happend. i flip the screen if you have the app on the left side. the L should point the otherway as well. I try to fix it on monday or tuesday. However is quick fix is putting the module op the right side in the config
      MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
      • P Offline
        Peter @Charley
        @Charley thanks.
        I will wait for the fix!
        No hurry.
        Peter
        • C Offline
          @Peter made an update this morning.
          The grouping must be set now and is not a default.
          If you like the same sensor with different values grouped add
          groupSensors: true
          To config.js for the module and the sensors will be grouped. However if the module is placed on a left position the hook └─ (right) ─┘(left) sometimes shows unexpected behavior.
          • C Offline
            To make the Domoticz System better I have made a WiFi Thermometer that is extremely precise. It is based on an infrared Non-touch sensor module. If you want to control devices this may be a good solution.
            Available on gitHub WiFi highly precise thermometer
              DavA
              I cant see anything but temperature? No status on switches ON or OFF.
              Also is it possible to not show all my temperature-sensors?
              • C Offline
                It shows only devices at are switched on.
                  Smotx
                  Thx for this module.
                  How to exclude Xiaomi doors sensors ?
                  Thx for help.
                  • C Offline
                    Today added support for p1 Smart meters
                    first update your module
                    cd MagicMirror/modules/MMM-Domoticz
                    git pull
                    pm2 restart MagicMirror
                    Add these 2 lines to the config file
                    smartMeter:  true,
                    smartMeterOffset: 0
                    You may need a commy behind the 0 from smartMeterOffset
                    The offset you use if the meter wasn’t zero when you moved in or if you want to show total per year of month
                    • C Offline
                      Charley Module Developer @Smotx
                      @Smotx
                      excluding can be done by adding the device names in the excludeDevices array in your config.js file
                        Awn
                        First of all, thank you for the hard work on those modules.
                        I’m nex to the MM world, and in the linux world in global, and it seems that I won’t be able to make it without your help.
                        The module shows “Loading Domoticz data…” and seems to never get them…
                        My config.js contains this :
                                                module: "MMM-Domoticz",
                                                position: "bottom_right",
                                                config:
                                                        updateInterval: 20,
                                                        apiBase: "https://192.168.**.***",
                                                        apiPort: 443,
                                                        apiUser: "**********",
                                                        apiPw: "*********",
                                                        moduleTitle: "Domoticz",
                                                        temperatureTitle: "Températures dans la maison",
                                                        subMenus: true,
                                                        showItems: ['temperature', 'humidity'],
                                                        textWhite: false,
                                                        groupSensors: true,
                        Sadly, it seems that the pi running the MM isn’t getting an answer from the pi running Domoticz.
                        I tried the url access from my browser:
                        https://192.168..*/json.htm?type=devices&filter=all&used=true&order=Name
                        I obtain a return with the different systems connected (RFXCom, Zwave, hue…)
                        Can somebody guide me throught this please?
                        Thanx !
                        Regards,
                        Awn
                        • 6
                        • 7
                        • 5 / 7
