    MMM-Domiticz
    68 Posts 18 Posters 54.9k Views 18 Watching
      art212 @MisterT
      @MisterT Ok thanks for the answer. What do you think? Is it possible to run MM and Domoticz together on one Raspberry Pi machine? Because I have a big problem with that. Domoticz is showing me instead of MM. I have to uninstall one for the other to work well …
        MisterT @art212
        @art212 i think it’s possible to run domoticz ans MM on the same raspberry. On terminal, if you write this command line, does domoticz appears on screen ?
        Sudo service domoticz restart
        If not domoticz is on but in background and You Can start MM with pm2
          Mazzokun @MisterT
          @MisterT Hi! I tried your code but it doesn’t work… in which folder in domoticz folder I have to copy the script?
          ty
            MisterT @Mazzokun
            @Mazzokun this command line is just for restart domoricz There is no link directly with magic mirror
            The command line in terminal (Home/pi/)
            Sudo service domoticz.sh status
            Just to know if domoticz is on or off
            Sudo service domoticz.sh restart
            Just to stop and start again domoticz
            Follow this link to start domoticz when raspberry boot
            https://www.domoticz.com/wiki/Linux
            And chapter
            Starting Domoticz automatically when the system boots
              art212 @MisterT
              @MisterT
              Hey, I do everything according to the guide https://github.com/M-Arvidsson/MMM-domoticz/ and I don’t know what’s wrong. I copied the code to MagicMirror/modules and then in config.js I set it like this:
              module: ‘marvidsson/domoticz’, //folder
              header: ‘Domoticz’,
              position: ‘top_left’,
              apiBase: “http://192.168.1.XXX”, //Domoticz IP
              apiPort: “80XX”, //Port
              apiUser: “XXX”,
              apiPw: “XXXXXX”,
              sensors: [
              idx: “2”, //Device IDX
              symbolon: “fa fa-user”, /font-awesome icon if device is On
              symboloff: “fa fa-user-o”, //font-awesome icon if device is Off (this will also be used if it is a temperature-de
              hiddenon: true, //true = hide if device is on (default: false)
              hiddenoff: false, //frue = hide if device is off (default: false)
              customTitle: “cwu”,
              idx: “2”,
              symbolon: “fa fa-circle-o-notch fa-spin”,
              symboloff: “fa fa-circle-o-notch”,
              idx: “2”,
              hiddenoff: false,
              idx: “88”,
              symbolon: “fa fa-tachometer”,
              symboloff: “fa fa-tachometer”,
              can u help me?
                art212
                This post is deleted!
                • N Offline
                  Nilnik Project Sponsor
                  Hello, I changed line 171 i domoticz.js from setTimeout(function() { to setInterval(function() { . It works for me. I have used this module for many years…```
                  Thisi my config:
                  			disabled: false,
                  			module: 'Nilnik/domoticz', //folder
                  			header: 'Domoticz Home Automation',
                  			position: 'bottom_right',
                  				apiBase: "http://xxx.xxx.x.xxx", //Domoticz IP
                  				apiPort: "xxxx", //Port
                  				updateInterval: 6000,
                  				sensors: [
                  					idx: "17", //Device IDX
                  					symbolon: "fa fa-unlock", //font-awesome icon if device is On
                  					symboloff: "fa fa-lock", //font-awesome icon if device is Off (this will also be used if it is a temperature-de
                  					idx: "3",
                  					idx: "16",
                  					idx: "1",
                  					idx: "2",
                  					symboloff: "fa fa-thermometer-half",
                  					idx: "10",
                  					symboloff:"fa fa-thermometer-half",
                  					idx: "11",
                  					//symbolon: "fa fa-thermometer-half",
                  					idx: "30",
                  					idx: "12",
                  				{	idx: "13",
                  				{	idx: "7",
                  					idx: "23",
                  					symboloff: "fa fa-user-lock",
                    Mazzokun @art212
                    @art212 said in MMM-Domiticz:
                    there isn’t a slash
                    symbolon: “fa fa-user”, //font-awesome icon if device is On
                    • 4 / 4
