    MMM-Domiticz
    68 Posts 18 Posters 61.5k Views 18 Watching
      MisterT @Mazzokun
      Hi @Mazzokun
      I had a problem with this module and with the help of @sdetweil a New code is available here. It works with domoticz password
      [link text] https://forum.magicmirror.builders/topic/11123/mmm-domoticz-cannot-read-property-0-of-undefined/13?page=2
      (link url)
      Enjoy
      M 1 Reply Last reply
      • A
        art212
        Hi, Are Domoticz and Magic Mirror installed on one Raspberry Pi? Are they two separate?
          MisterT @art212
          @art212 Domoticz and Magic mirror are separate. In the config.js, just complete the Ip adress of Domoticz Device and Domoticz user and password if need. In my case, Domoticz is on a raspberry and my magic mirror on a other one
          A 1 Reply Last reply
          • A
            art212 @MisterT
            @MisterT Ok thanks for the answer. What do you think? Is it possible to run MM and Domoticz together on one Raspberry Pi machine? Because I have a big problem with that. Domoticz is showing me instead of MM. I have to uninstall one for the other to work well …
              MisterT @art212
              @art212 i think it’s possible to run domoticz ans MM on the same raspberry. On terminal, if you write this command line, does domoticz appears on screen ?
              Sudo service domoticz restart
              If not domoticz is on but in background and You Can start MM with pm2
                Mazzokun @MisterT
                @MisterT Hi! I tried your code but it doesn’t work… in which folder in domoticz folder I have to copy the script?
                ty
                  MisterT @Mazzokun
                  @Mazzokun this command line is just for restart domoricz There is no link directly with magic mirror
                  The command line in terminal (Home/pi/)
                  Sudo service domoticz.sh status
                  Just to know if domoticz is on or off
                  Sudo service domoticz.sh restart
                  Just to stop and start again domoticz
                  Follow this link to start domoticz when raspberry boot
                  https://www.domoticz.com/wiki/Linux
                  And chapter
                  Starting Domoticz automatically when the system boots
                  • A
                    art212 @MisterT
                    @MisterT
                    Hey, I do everything according to the guide https://github.com/M-Arvidsson/MMM-domoticz/ and I don’t know what’s wrong. I copied the code to MagicMirror/modules and then in config.js I set it like this:
                    module: ‘marvidsson/domoticz’, //folder
                    header: ‘Domoticz’,
                    position: ‘top_left’,
                    apiBase: “http://192.168.1.XXX”, //Domoticz IP
                    apiPort: “80XX”, //Port
                    apiUser: “XXX”,
                    apiPw: “XXXXXX”,
                    sensors: [
                    idx: “2”, //Device IDX
                    symbolon: “fa fa-user”, /font-awesome icon if device is On
                    symboloff: “fa fa-user-o”, //font-awesome icon if device is Off (this will also be used if it is a temperature-de
                    hiddenon: true, //true = hide if device is on (default: false)
                    hiddenoff: false, //frue = hide if device is off (default: false)
                    customTitle: “cwu”,
                    idx: “2”,
                    symbolon: “fa fa-circle-o-notch fa-spin”,
                    symboloff: “fa fa-circle-o-notch”,
                    idx: “2”,
                    hiddenoff: false,
                    idx: “88”,
                    symbolon: “fa fa-tachometer”,
                    symboloff: “fa fa-tachometer”,
                    can u help me?
                    • A
                      art212
                      • N
                        Nilnik Project Sponsor
                        Hello, I changed line 171 i domoticz.js from setTimeout(function() { to setInterval(function() { . It works for me. I have used this module for many years…```
                        Thisi my config:
                        			disabled: false,
                        			module: 'Nilnik/domoticz', //folder
                        			header: 'Domoticz Home Automation',
                        			position: 'bottom_right',
                        				apiBase: "http://xxx.xxx.x.xxx", //Domoticz IP
                        				apiPort: "xxxx", //Port
                        				updateInterval: 6000,
                        				sensors: [
                        					idx: "17", //Device IDX
                        					symbolon: "fa fa-unlock", //font-awesome icon if device is On
                        					symboloff: "fa fa-lock", //font-awesome icon if device is Off (this will also be used if it is a temperature-de
                        					idx: "3",
                        					idx: "16",
                        					idx: "1",
                        					idx: "2",
                        					symboloff: "fa fa-thermometer-half",
                        					idx: "10",
                        					symboloff:"fa fa-thermometer-half",
                        					idx: "11",
                        					//symbolon: "fa fa-thermometer-half",
                        					idx: "30",
                        					idx: "12",
                        				{	idx: "13",
                        				{	idx: "7",
                        					idx: "23",
                        					symboloff: "fa fa-user-lock",
                          Mazzokun @art212
                          @art212 said in MMM-Domiticz:
                          there isn’t a slash
                          symbolon: “fa fa-user”, //font-awesome icon if device is On
                          • 4 / 4
