    MMM-Domiticz
    68 Posts 18 Posters 58.9k Views 18 Watching
    • T Offline
      ToniNappi
      Is it possible also exclude sensors from the displayed data? I have about 50 temp sensors and obviously I want only see the most important ones. I tried to put them in exlude list, but it doesn’t seem to work. Nice module still!
      Toni
      • N Offline
        najtram
        Hi, there.
        Great module!
        It’s passing the described data perfectly except one of my top desired data.
        I’d really love to see “CounterToday” and “Data” from my Enphase Envoy.
        Since this is a kWh subtype it looks like I’m really close, but somehow I only see my P1 data.
             "AddjMulti" : 1.0,
             "AddjMulti2" : 1.0,
             "AddjValue" : 0.0,
             "AddjValue2" : 0.0,
             "BatteryLevel" : 255,
             "CounterToday" : "0.117 kWh",
             "CustomImage" : 0,
             "Data" : "486.173 kWh",
             "Description" : "",
             "Favorite" : 0,
             "HardwareID" : 9,
             "HardwareName" : "Enphase Envoy",
             "HardwareType" : "Enphase Envoy with LAN (HTTP) interface",
             "HardwareTypeVal" : 108,
             "HaveTimeout" : false,
             "ID" : "00000901",
             "LastUpdate" : "2020-09-13 08:31:50",
             "Name" : "Enphase kWh Production",
             "Notifications" : "false",
             "Options" : "",
             "PlanID" : "0",
             "PlanIDs" : [ 0 ],
             "Protected" : false,
             "ShowNotifications" : true,
             "SignalLevel" : "-",
             "SubType" : "kWh",
             "SwitchTypeVal" : 0,
             "Timers" : "false",
             "Type" : "General",
             "TypeImg" : "current",
             "Unit" : 1,
             "Usage" : "280 Watt",
             "Used" : 1,
             "XOffset" : "0",
             "YOffset" : "0",
             "idx" : "748"
          Sp0nsje
          Hi thanks for the great work,
          Is there a better guide on how to implement certain sensors ?
          like an ‘‘IDX xx’’ value or something
                                  module: "MMM-Domoticz",
                                  position: "bottom_right",   // see mirror setting for options
                                          updateInterval: 5, // every 45 seconds
                                          apiBase: "192.168.178.44",
                                          apiPort: 18080,
                                          apiUser: "MagicMirror",
                                          apiPw: "MagicMirror",
                                          moduleTitle: "My smart home by Domoticz",
                                          energyTitle: "Energy used by",
                                          batteryTitle: "Battery level",
                                          coTitle: "CO2 level",
                                          blindsTitle: "Blinds",
                                          energyNow: "Currently using",
                                          energyTotal: "Energy used",
                                          energyToday: "Energy used today",
                                          batteryThreshold: 20,
                                          coThreshold: 650,
                                          subMenus: true,
                                          smartMeter: false,
                                          smartMeterOffset: 0,
                                          showItems: ['temperature'], //,'energy','battery','co','blinds','humidity','baro','usage','voltage','alarm','sensor','pulse','meter','rain'],
                                          excludeDevices: ['none','include your own'],  // Device that will not be shown
                                          onlyShowExcluded: false, // if true only exluded devices are shown
                                          textWhite: true,
                                          alarmOffLabel: "Disabled",
                                          groupSensors: false,
          i can only show the temperatures when i select al the data it wil hang on Loading Domoticz Data…
          would appriciate different screenshots of codes / layouts on the MM2
            Mazzokun
            I think there is something broken into code or there is some dependence-package with raspberryOs…
            In Domoticz I have 30+ devices and In MM shows only a meter device with 0,0,0 values ( I have 3 meter device, no possible value)…
            If I try open the json url into chromium it says error 401 forbidden, but if I try the same url into Mac safari it simple works.
            Any Idea?
              MisterT @Mazzokun
              Hi @Mazzokun
              I had a problem with this module and with the help of @sdetweil a New code is available here. It works with domoticz password
              [link text] https://forum.magicmirror.builders/topic/11123/mmm-domoticz-cannot-read-property-0-of-undefined/13?page=2
              (link url)
              Enjoy
                art212
                Hi, Are Domoticz and Magic Mirror installed on one Raspberry Pi? Are they two separate?
                  MisterT @art212
                  @art212 Domoticz and Magic mirror are separate. In the config.js, just complete the Ip adress of Domoticz Device and Domoticz user and password if need. In my case, Domoticz is on a raspberry and my magic mirror on a other one
                  A 1 Reply Last reply Reply Quote 1
                    art212 @MisterT
                    @MisterT Ok thanks for the answer. What do you think? Is it possible to run MM and Domoticz together on one Raspberry Pi machine? Because I have a big problem with that. Domoticz is showing me instead of MM. I have to uninstall one for the other to work well …
                      MisterT @art212
                      @art212 i think it’s possible to run domoticz ans MM on the same raspberry. On terminal, if you write this command line, does domoticz appears on screen ?
                      Sudo service domoticz restart
                      If not domoticz is on but in background and You Can start MM with pm2
                        Mazzokun @MisterT
                        @MisterT Hi! I tried your code but it doesn’t work… in which folder in domoticz folder I have to copy the script?
                        ty
                          MisterT @Mazzokun
                          @Mazzokun this command line is just for restart domoricz There is no link directly with magic mirror
                          The command line in terminal (Home/pi/)
                          Sudo service domoticz.sh status
                          Just to know if domoticz is on or off
                          Sudo service domoticz.sh restart
                          Just to stop and start again domoticz
                          Follow this link to start domoticz when raspberry boot
                          https://www.domoticz.com/wiki/Linux
                          And chapter
                          Starting Domoticz automatically when the system boots
                            art212 @MisterT
                            @MisterT
                            Hey, I do everything according to the guide https://github.com/M-Arvidsson/MMM-domoticz/ and I don’t know what’s wrong. I copied the code to MagicMirror/modules and then in config.js I set it like this:
                            module: ‘marvidsson/domoticz’, //folder
                            header: ‘Domoticz’,
                            position: ‘top_left’,
                            apiBase: “http://192.168.1.XXX”, //Domoticz IP
                            apiPort: “80XX”, //Port
                            apiUser: “XXX”,
                            apiPw: “XXXXXX”,
                            sensors: [
                            idx: “2”, //Device IDX
                            symbolon: “fa fa-user”, /font-awesome icon if device is On
                            symboloff: “fa fa-user-o”, //font-awesome icon if device is Off (this will also be used if it is a temperature-de
                            hiddenon: true, //true = hide if device is on (default: false)
                            hiddenoff: false, //frue = hide if device is off (default: false)
                            customTitle: “cwu”,
                            idx: “2”,
                            symbolon: “fa fa-circle-o-notch fa-spin”,
                            symboloff: “fa fa-circle-o-notch”,
                            idx: “2”,
                            hiddenoff: false,
                            idx: “88”,
                            symbolon: “fa fa-tachometer”,
                            symboloff: “fa fa-tachometer”,
                            can u help me?
                              art212
                              • N Offline
                                Nilnik Project Sponsor
                                Hello, I changed line 171 i domoticz.js from setTimeout(function() { to setInterval(function() { . It works for me. I have used this module for many years…```
                                Thisi my config:
                                			disabled: false,
                                			module: 'Nilnik/domoticz', //folder
                                			header: 'Domoticz Home Automation',
                                			position: 'bottom_right',
                                				apiBase: "http://xxx.xxx.x.xxx", //Domoticz IP
                                				apiPort: "xxxx", //Port
                                				updateInterval: 6000,
                                				sensors: [
                                					idx: "17", //Device IDX
                                					symbolon: "fa fa-unlock", //font-awesome icon if device is On
                                					symboloff: "fa fa-lock", //font-awesome icon if device is Off (this will also be used if it is a temperature-de
                                					idx: "3",
                                					idx: "16",
                                					idx: "1",
                                					idx: "2",
                                					symboloff: "fa fa-thermometer-half",
                                					idx: "10",
                                					symboloff:"fa fa-thermometer-half",
                                					idx: "11",
                                					//symbolon: "fa fa-thermometer-half",
                                					idx: "30",
                                					idx: "12",
                                				{	idx: "13",
                                				{	idx: "7",
                                					idx: "23",
                                					symboloff: "fa fa-user-lock",
                                  Mazzokun @art212
                                  @art212 said in MMM-Domiticz:
                                  there isn’t a slash
                                  symbolon: “fa fa-user”, //font-awesome icon if device is On
                                  • 4 / 4
