    MMM-Domiticz
    68 Posts 18 Posters 60.9k Views 18 Watching
    • C
      Charley Module Developer
      @peter
      I am sorry this happend. i flip the screen if you have the app on the left side. the L should point the otherway as well. I try to fix it on monday or tuesday. However is quick fix is putting the module op the right side in the config
      MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
      P 1 Reply Last reply
      • P
        Peter @Charley
        @Charley thanks.
        I will wait for the fix!
        No hurry.
        Peter
        • C
          @Peter made an update this morning.
          The grouping must be set now and is not a default.
          If you like the same sensor with different values grouped add
          groupSensors: true
          To config.js for the module and the sensors will be grouped. However if the module is placed on a left position the hook └─ (right) ─┘(left) sometimes shows unexpected behavior.
          • C
            To make the Domoticz System better I have made a WiFi Thermometer that is extremely precise. It is based on an infrared Non-touch sensor module. If you want to control devices this may be a good solution.
            Available on gitHub WiFi highly precise thermometer
            • D
              DavA
              I cant see anything but temperature? No status on switches ON or OFF.
              Also is it possible to not show all my temperature-sensors?
              • C
                It shows only devices at are switched on.
                  Smotx
                  Thx for this module.
                  How to exclude Xiaomi doors sensors ?
                  Thx for help.
                  C 1 Reply Last reply
                  • C
                    Today added support for p1 Smart meters
                    first update your module
                    cd MagicMirror/modules/MMM-Domoticz
                    git pull
                    pm2 restart MagicMirror
                    Add these 2 lines to the config file
                    smartMeter:  true,
                    smartMeterOffset: 0
                    You may need a commy behind the 0 from smartMeterOffset
                    The offset you use if the meter wasn’t zero when you moved in or if you want to show total per year of month
                    • C
                      Charley Module Developer @Smotx
                      @Smotx
                      excluding can be done by adding the device names in the excludeDevices array in your config.js file
                      • A
                        Awn
                        First of all, thank you for the hard work on those modules.
                        I’m nex to the MM world, and in the linux world in global, and it seems that I won’t be able to make it without your help.
                        The module shows “Loading Domoticz data…” and seems to never get them…
                        My config.js contains this :
                                                module: "MMM-Domoticz",
                                                position: "bottom_right",
                                                config:
                                                        updateInterval: 20,
                                                        apiBase: "https://192.168.**.***",
                                                        apiPort: 443,
                                                        apiUser: "**********",
                                                        apiPw: "*********",
                                                        moduleTitle: "Domoticz",
                                                        temperatureTitle: "Températures dans la maison",
                                                        subMenus: true,
                                                        showItems: ['temperature', 'humidity'],
                                                        textWhite: false,
                                                        groupSensors: true,
                        Sadly, it seems that the pi running the MM isn’t getting an answer from the pi running Domoticz.
                        I tried the url access from my browser:
                        https://192.168..*/json.htm?type=devices&filter=all&used=true&order=Name
                        I obtain a return with the different systems connected (RFXCom, Zwave, hue…)
                        Can somebody guide me throught this please?
                        Thanx !
                        Regards,
                        Awn
                        • P
                          Pl4nk
                          This post is deleted!
                            sdetweil @Awn
                            @Awn on the magicmirror, using the keyboard, open the developers window, ctrl-shift-i,
                            select the tab labeled console, on the window that opens, scroll up to see any errors
                            u may also have to look in the terminal window log for errors from the node_helper
                            these will be in the pm2 logs if using pm2.
                            do
                            pm2 logs --lines=100
                            • J
                              Jo-Rien
                              I am not getting a neat list with this module, all readings from my temperature meters is shown on two lines and it’s kinda messing up the screen. Any idea what the problem is?
                              • T
                                ToniNappi
                                Is it possible also exclude sensors from the displayed data? I have about 50 temp sensors and obviously I want only see the most important ones. I tried to put them in exlude list, but it doesn’t seem to work. Nice module still!
                                Toni
                                • N
                                  najtram
                                  Hi, there.
                                  Great module!
                                  It’s passing the described data perfectly except one of my top desired data.
                                  I’d really love to see “CounterToday” and “Data” from my Enphase Envoy.
                                  Since this is a kWh subtype it looks like I’m really close, but somehow I only see my P1 data.
                                       "AddjMulti" : 1.0,
                                       "AddjMulti2" : 1.0,
                                       "AddjValue" : 0.0,
                                       "AddjValue2" : 0.0,
                                       "BatteryLevel" : 255,
                                       "CounterToday" : "0.117 kWh",
                                       "CustomImage" : 0,
                                       "Data" : "486.173 kWh",
                                       "Description" : "",
                                       "Favorite" : 0,
                                       "HardwareID" : 9,
                                       "HardwareName" : "Enphase Envoy",
                                       "HardwareType" : "Enphase Envoy with LAN (HTTP) interface",
                                       "HardwareTypeVal" : 108,
                                       "HaveTimeout" : false,
                                       "ID" : "00000901",
                                       "LastUpdate" : "2020-09-13 08:31:50",
                                       "Name" : "Enphase kWh Production",
                                       "Notifications" : "false",
                                       "Options" : "",
                                       "PlanID" : "0",
                                       "PlanIDs" : [ 0 ],
                                       "Protected" : false,
                                       "ShowNotifications" : true,
                                       "SignalLevel" : "-",
                                       "SubType" : "kWh",
                                       "SwitchTypeVal" : 0,
                                       "Timers" : "false",
                                       "Type" : "General",
                                       "TypeImg" : "current",
                                       "Unit" : 1,
                                       "Usage" : "280 Watt",
                                       "Used" : 1,
                                       "XOffset" : "0",
                                       "YOffset" : "0",
                                       "idx" : "748"
                                    Sp0nsje
                                    Hi thanks for the great work,
                                    Is there a better guide on how to implement certain sensors ?
                                    like an ‘‘IDX xx’’ value or something
                                                            position: "bottom_right",   // see mirror setting for options
        updateInterval: 5, // every 45 seconds
        apiBase: "192.168.178.44",
        apiPort: 18080,
        apiUser: "MagicMirror",
        apiPw: "MagicMirror",
        moduleTitle: "My smart home by Domoticz",
        energyTitle: "Energy used by",
        batteryTitle: "Battery level",
        coTitle: "CO2 level",
        blindsTitle: "Blinds",
        energyNow: "Currently using",
        energyTotal: "Energy used",
        energyToday: "Energy used today",
        batteryThreshold: 20,
        coThreshold: 650,
        subMenus: true,
        smartMeter: false,
        smartMeterOffset: 0,
        showItems: ['temperature'], //,'energy','battery','co','blinds','humidity','baro','usage','voltage','alarm','sensor','pulse','meter','rain'],
        excludeDevices: ['none','include your own'],  // Device that will not be shown
        onlyShowExcluded: false, // if true only exluded devices are shown
        textWhite: true,
        alarmOffLabel: "Disabled",
        groupSensors: false,
                                    i can only show the temperatures when i select al the data it wil hang on Loading Domoticz Data…
                                    would appriciate different screenshots of codes / layouts on the MM2
                                    • M
                                      Mazzokun
                                      I think there is something broken into code or there is some dependence-package with raspberryOs…
                                      In Domoticz I have 30+ devices and In MM shows only a meter device with 0,0,0 values ( I have 3 meter device, no possible value)…
                                      If I try open the json url into chromium it says error 401 forbidden, but if I try the same url into Mac safari it simple works.
                                      Any Idea?
                                      M 1 Reply Last reply
                                      • M
                                        MisterT @Mazzokun
                                        Hi @Mazzokun
                                        I had a problem with this module and with the help of @sdetweil a New code is available here. It works with domoticz password
                                        [link text] https://forum.magicmirror.builders/topic/11123/mmm-domoticz-cannot-read-property-0-of-undefined/13?page=2
                                        (link url)
                                        Enjoy
                                        • A
                                          art212
                                          Hi, Are Domoticz and Magic Mirror installed on one Raspberry Pi? Are they two separate?
                                          • M
                                            MisterT @art212
                                            @art212 Domoticz and Magic mirror are separate. In the config.js, just complete the Ip adress of Domoticz Device and Domoticz user and password if need. In my case, Domoticz is on a raspberry and my magic mirror on a other one
                                            A 1 Reply Last reply
                                            Reply Quote 1
                                            • 3 / 4
