    MMM-Domiticz
    68 Posts 18 Posters 61.5k Views 18 Watching
      jaminben
      @Charley said in MMM-Domiticz:
      textWhite:true
      All working great now… many thanks for taking the time to look at this for me :)
        Peter
        Maybe a stupid question; do I have to make the changes in MM config.js file or in Domoticz.js file?
        Peter
          Charley Module Developer
          @Peter there are no stupid questions
          You should make the changes in the MagicMirror config.js file, if you make them in the MMM-Domoticz.js they will be gone in the next updates.
          In the MMM-Domoticz.js that are the default values if you don’t put it in the MM config.js file the value from the module will be used.
          Good luck
          MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
            Peter
            Sorry, Charley, I deleted Domoticz folder, installed again and now I have a problem:
            How can I solve this?
            Peter
              @peter
              I am sorry this happend. i flip the screen if you have the app on the left side. the L should point the otherway as well. I try to fix it on monday or tuesday. However is quick fix is putting the module op the right side in the config
              P 1 Reply Last reply
                Peter @Charley
                @Charley thanks.
                I will wait for the fix!
                No hurry.
                Peter
                  @Peter made an update this morning.
                  The grouping must be set now and is not a default.
                  If you like the same sensor with different values grouped add
                  groupSensors: true
                  To config.js for the module and the sensors will be grouped. However if the module is placed on a left position the hook └─ (right) ─┘(left) sometimes shows unexpected behavior.
                    To make the Domoticz System better I have made a WiFi Thermometer that is extremely precise. It is based on an infrared Non-touch sensor module. If you want to control devices this may be a good solution.
                    Available on gitHub WiFi highly precise thermometer
                      DavA
                      I cant see anything but temperature? No status on switches ON or OFF.
                      Also is it possible to not show all my temperature-sensors?
                        It shows only devices at are switched on.
                          Smotx
                          Thx for this module.
                          How to exclude Xiaomi doors sensors ?
                          Thx for help.
                          C 1 Reply Last reply
                            Today added support for p1 Smart meters
                            first update your module
                            cd MagicMirror/modules/MMM-Domoticz
                            git pull
                            pm2 restart MagicMirror
                            Add these 2 lines to the config file
                            smartMeter:  true,
                            smartMeterOffset: 0
                            You may need a commy behind the 0 from smartMeterOffset
                            The offset you use if the meter wasn’t zero when you moved in or if you want to show total per year of month
                              Charley Module Developer @Smotx
                              @Smotx
                              excluding can be done by adding the device names in the excludeDevices array in your config.js file
                              • A
                                Awn
                                First of all, thank you for the hard work on those modules.
                                I’m nex to the MM world, and in the linux world in global, and it seems that I won’t be able to make it without your help.
                                The module shows “Loading Domoticz data…” and seems to never get them…
                                My config.js contains this :
                                                        module: "MMM-Domoticz",
                                                        position: "bottom_right",
                                                        config:
        updateInterval: 20,
        apiBase: "https://192.168.**.***",
        apiPort: 443,
        apiUser: "**********",
        apiPw: "*********",
        moduleTitle: "Domoticz",
        temperatureTitle: "Températures dans la maison",
        subMenus: true,
        showItems: ['temperature', 'humidity'],
        textWhite: false,
        groupSensors: true,
                                Sadly, it seems that the pi running the MM isn’t getting an answer from the pi running Domoticz.
                                I tried the url access from my browser:
                                https://192.168..*/json.htm?type=devices&filter=all&used=true&order=Name
                                I obtain a return with the different systems connected (RFXCom, Zwave, hue…)
                                Can somebody guide me throught this please?
                                Thanx !
                                Regards,
                                Awn
                                  Pl4nk
                                    sdetweil @Awn
                                    @Awn on the magicmirror, using the keyboard, open the developers window, ctrl-shift-i,
                                    select the tab labeled console, on the window that opens, scroll up to see any errors
                                    u may also have to look in the terminal window log for errors from the node_helper
                                    these will be in the pm2 logs if using pm2.
                                    do
                                    pm2 logs --lines=100
                                      Jo-Rien
                                      I am not getting a neat list with this module, all readings from my temperature meters is shown on two lines and it’s kinda messing up the screen. Any idea what the problem is?
                                      • T
                                        ToniNappi
                                        Is it possible also exclude sensors from the displayed data? I have about 50 temp sensors and obviously I want only see the most important ones. I tried to put them in exlude list, but it doesn’t seem to work. Nice module still!
                                        Toni
                                        • N
                                          najtram
                                          Hi, there.
                                          Great module!
                                          It’s passing the described data perfectly except one of my top desired data.
                                          I’d really love to see “CounterToday” and “Data” from my Enphase Envoy.
                                          Since this is a kWh subtype it looks like I’m really close, but somehow I only see my P1 data.
                                               "AddjMulti" : 1.0,
                                               "AddjMulti2" : 1.0,
                                               "AddjValue" : 0.0,
                                               "AddjValue2" : 0.0,
                                               "BatteryLevel" : 255,
                                               "CounterToday" : "0.117 kWh",
                                               "CustomImage" : 0,
                                               "Data" : "486.173 kWh",
                                               "Description" : "",
                                               "Favorite" : 0,
                                               "HardwareID" : 9,
                                               "HardwareName" : "Enphase Envoy",
                                               "HardwareType" : "Enphase Envoy with LAN (HTTP) interface",
                                               "HardwareTypeVal" : 108,
                                               "HaveTimeout" : false,
                                               "ID" : "00000901",
                                               "LastUpdate" : "2020-09-13 08:31:50",
                                               "Name" : "Enphase kWh Production",
                                               "Notifications" : "false",
                                               "Options" : "",
                                               "PlanID" : "0",
                                               "PlanIDs" : [ 0 ],
                                               "Protected" : false,
                                               "ShowNotifications" : true,
                                               "SignalLevel" : "-",
                                               "SubType" : "kWh",
                                               "SwitchTypeVal" : 0,
                                               "Timers" : "false",
                                               "Type" : "General",
                                               "TypeImg" : "current",
                                               "Unit" : 1,
                                               "Usage" : "280 Watt",
                                               "Used" : 1,
                                               "XOffset" : "0",
                                               "YOffset" : "0",
                                               "idx" : "748"
                                            Sp0nsje
                                            Hi thanks for the great work,
                                            Is there a better guide on how to implement certain sensors ?
                                            like an ‘‘IDX xx’’ value or something
        position: "bottom_right",   // see mirror setting for options
        updateInterval: 5, // every 45 seconds
        apiBase: "192.168.178.44",
        apiPort: 18080,
        apiUser: "MagicMirror",
        apiPw: "MagicMirror",
        moduleTitle: "My smart home by Domoticz",
        energyTitle: "Energy used by",
        batteryTitle: "Battery level",
        coTitle: "CO2 level",
        blindsTitle: "Blinds",
        energyNow: "Currently using",
        energyTotal: "Energy used",
        energyToday: "Energy used today",
        batteryThreshold: 20,
        coThreshold: 650,
        subMenus: true,
        smartMeter: false,
        smartMeterOffset: 0,
        showItems: ['temperature'], //,'energy','battery','co','blinds','humidity','baro','usage','voltage','alarm','sensor','pulse','meter','rain'],
        excludeDevices: ['none','include your own'],  // Device that will not be shown
        onlyShowExcluded: false, // if true only exluded devices are shown
        textWhite: true,
        alarmOffLabel: "Disabled",
        groupSensors: false,
                                            i can only show the temperatures when i select al the data it wil hang on Loading Domoticz Data…
                                            would appriciate different screenshots of codes / layouts on the MM2
                                            • 3 / 4
