    MMM-Domiticz
    68 Posts 18 Posters 61.4k Views 18 Watching
      jaminben @Charley
      @Charley said in MMM-Domiticz:
      @jaminben
      I already tried before to reorder the data. In the description of API/JSON for Domoticz it says you can order by Name. (Line 37 in my code)
      That is the documentation, but in reality you can’t order anything. If I look in the json coming from the request file there are no objects that would follow the order in your webapplication.
      It could be done my making an array where all sensors are switches are in, but it would be a hassle if you add a new device you would also need to add to your modules config.
      Lets wait what the next version of Domoticz brings and if I am able to implement it.
      Not sure if you saw my previous comment and I’m not sure if it’s a fluke but I re-ordered my sensors within my Domoticz dashboard and they automatically re-ordered themselves within your module on the MM to match… probably a coincidence but mines looking exactly how I want them :)
        Charley Module Developer
        @jaminben Thanks I will arrange them in my Dashboard as well.
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          Today added total actual usage of Watts.
          Please add ‘usage’ to your showItems in your config.js
            jaminben
            Hi Charley,
            Is it possible to get the colour of the values and icons to be white rather than grey?
            Ben
              Today I have added to set the text colour to White.
              Just add in your config.js the option
              textWhite:true
                jaminben
                I updated and adding the config option ‘textWhite: true,’ but it doesn’t appear to work… any ideas?
                  Made a small change it should work now
                    jaminben
                      jaminben
                      textWhite:true
                      All working great now… many thanks for taking the time to look at this for me :)
                        Peter
                        Maybe a stupid question; do I have to make the changes in MM config.js file or in Domoticz.js file?
                        Peter
                          @Peter there are no stupid questions
                          You should make the changes in the MagicMirror config.js file, if you make them in the MMM-Domoticz.js they will be gone in the next updates.
                          In the MMM-Domoticz.js that are the default values if you don’t put it in the MM config.js file the value from the module will be used.
                          Good luck
                            Peter
                            Sorry, Charley, I deleted Domoticz folder, installed again and now I have a problem:
                            How can I solve this?
                            Peter
                              @peter
                              I am sorry this happend. i flip the screen if you have the app on the left side. the L should point the otherway as well. I try to fix it on monday or tuesday. However is quick fix is putting the module op the right side in the config
                              P 1 Reply Last reply
                                Peter @Charley
                                @Charley thanks.
                                I will wait for the fix!
                                No hurry.
                                Peter
                                  @Peter made an update this morning.
                                  The grouping must be set now and is not a default.
                                  If you like the same sensor with different values grouped add
                                  groupSensors: true
                                  To config.js for the module and the sensors will be grouped. However if the module is placed on a left position the hook └─ (right) ─┘(left) sometimes shows unexpected behavior.
                                    To make the Domoticz System better I have made a WiFi Thermometer that is extremely precise. It is based on an infrared Non-touch sensor module. If you want to control devices this may be a good solution.
                                    Available on gitHub WiFi highly precise thermometer
                                      DavA
                                      I cant see anything but temperature? No status on switches ON or OFF.
                                      Also is it possible to not show all my temperature-sensors?
                                        It shows only devices at are switched on.
                                          Smotx
                                          Thx for this module.
                                          How to exclude Xiaomi doors sensors ?
                                          Thx for help.
                                          C 1 Reply Last reply
                                            Today added support for p1 Smart meters
                                            first update your module
                                            cd MagicMirror/modules/MMM-Domoticz
                                            git pull
                                            pm2 restart MagicMirror
                                            Add these 2 lines to the config file
                                            smartMeter:  true,
                                            smartMeterOffset: 0
                                            You may need a commy behind the 0 from smartMeterOffset
                                            The offset you use if the meter wasn’t zero when you moved in or if you want to show total per year of month
                                            • 2 / 4
