    MMM-Domiticz
    68 Posts 18 Posters 58.1k Views 18 Watching
      jaminben @Charley
      @Charley said in MMM-Domiticz:
      @jaminben Thanks for the thank you, i am still working on it to make it better.
      You can add more in your config.js settings
            showItems: ['temperature','energy','battery','co', 'blinds','humidity','baro'],   // possible items  temperature, energy, battery, co, blinds, humidity,  baro
      Could you please reply with your config settings for this module .(delete any personal information ip,username or password)
      I think I misread your question, however all sensors data are grouped in the newest version.
      @Charley
      My config.js file…
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: ******,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "********"], // Set [] to allow all IP addresses
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "*******",
      						symbol: "calendar-check-o ",
      						url: "********"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "*****",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "******"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "*******",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "*****"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "BBC News",
      						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
      				showSourceTitle: true,
      				showPublishDate: true
      			module: "MMM-Domoticz",
      			position: "top_right",   // see mirror setting for options
      				updateInterval: 45, // every 45 seconds
      				apiBase: '******',
      				apiPort: ****,
      				apiUser: "*******",
      					apiPw: "********",
      				temperatureTitle: "Current House Temperatures",
      				moduleTitle: "My smart home by Domoticz",
      				energyTitle: "Energy used by",
      				batteryTitle: "Battery level",
      				coTitle: "CO2 level",
      				blindsTitle: "Blinds",
      				energyNow: "Currently",
      				energyTotal: "Energy used",
      				batteryThreshold: 20,
      						coThreshold: 650,
      				subMenus: true,
      				showItems: ['temperature'],   // possible items  temperature, energy
      				excludedDevices: ['none','add your own']  // Device that will not be shown
      			module: 'MMM-Todoist',
      			position: 'top_right',	// This can be any of the regions. Best results in left or right regions.
      			header: 'Todoist', // This is optional
      			config: { // See 'Configuration options' for more information.
      				accessToken: '********',
      				maximumEntries: 60,
      				updateInterval: 10*60*1000, // Update every 10 minutes
      				projects: [ 166564794 ],
      				fade: false
      What I was trying to was something like:
      Garden 24.1 (temperature)
      55% (humidity)
      Lounge 20.2 (temperature)
      45% (humidity)
      Garage 22.1 (temperature)
      48% (humidity)
      Rather than:
      Garden 55% (humidity)
      Lounge 45% (humidity)
      Garage 48% (humidity)
        jaminben
        @Charley
        I just updated to the new version and it only shows the temperature now… not sure if that was intended or not.
          Charley Module Developer
          You need to add humidity and baro to the showItems part in config.js
          to see all options (someone asked in PM to block humidity)
          It will now show the way you like it
          MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
            jaminben @Charley
            @Charley
            Very cool… can I make one suggestion? How about if it detects that it already has a name present for the temperature it doesn’t display the name for the humidity and/or baro just the value? That way you don’t get duplicate names for the same sensor.
            I can see in yours you have Woonkamer (Living Room) repeated 3 times which I assume is the same sensor?
              Yes they are all the same sensor. I will try in the coming days if I am able to get those properly.
              Just made it. if you pull the upgrade it is there
                jaminben @Charley
                Very nice… it works as expected :)
                Next request… is there a way to sort them some how?
                Sorry, I know I’m a PITA.
                  jaminben @jaminben
                  @Charley
                  Ah, no… ignore my last comment. I can sort them via my Domoticz Dashboard.
                  Once again, MANY THANKS… I really appreciate the work you’ve done.
                  Very Cool Stuff.
                    @jaminben
                    I already tried before to reorder the data. In the description of API/JSON for Domoticz it says you can order by Name. (Line 37 in my code)
                    That is the documentation, but in reality you can’t order anything. If I look in the json coming from the request file there are no objects that would follow the order in your webapplication.
                    It could be done my making an array where all sensors are switches are in, but it would be a hassle if you add a new device you would also need to add to your modules config.
                    Lets wait what the next version of Domoticz brings and if I am able to implement it.
                      jaminben @Charley
                      @jaminben
                      Not sure if you saw my previous comment and I’m not sure if it’s a fluke but I re-ordered my sensors within my Domoticz dashboard and they automatically re-ordered themselves within your module on the MM to match… probably a coincidence but mines looking exactly how I want them :)
                        @jaminben Thanks I will arrange them in my Dashboard as well.
                          Today added total actual usage of Watts.
                          Please add ‘usage’ to your showItems in your config.js
                            jaminben
                            Hi Charley,
                            Is it possible to get the colour of the values and icons to be white rather than grey?
                            Ben
                              Today I have added to set the text colour to White.
                              Just add in your config.js the option
                              textWhite:true
                                jaminben
                                I updated and adding the config option ‘textWhite: true,’ but it doesn’t appear to work… any ideas?
                                  Made a small change it should work now
                                    jaminben
                                      jaminben
                                      textWhite:true
                                      All working great now… many thanks for taking the time to look at this for me :)
                                        Peter
                                        Maybe a stupid question; do I have to make the changes in MM config.js file or in Domoticz.js file?
                                        Peter
                                          @Peter there are no stupid questions
                                          You should make the changes in the MagicMirror config.js file, if you make them in the MMM-Domoticz.js they will be gone in the next updates.
                                          In the MMM-Domoticz.js that are the default values if you don’t put it in the MM config.js file the value from the module will be used.
                                          Good luck
                                            Peter
                                            Sorry, Charley, I deleted Domoticz folder, installed again and now I have a problem:
                                            How can I solve this?
                                            Peter
                                            • 2 / 4
