    MMM-Domiticz
    68 Posts 18 Posters 61.4k Views 18 Watching
      Charley Module Developer
      @Peter What colours would you like and for what state (On, Off, Open Close)
      MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
        Peter
        Maybe lights off, outlets off and screens open in white.
        Lights on, outlets on and screens down in yellow.
        Peter
          I have added colour yellow to closed Blinds/shutters.
          There is no added colour to lights, outlets because the are not visible when they are inactive.
          However if you like to add a colour you can change the code in line 72
          make sure you have a space between small and yellow just before the i-element for the icons
          P 1 Reply Last reply
            Peter @Charley
            @Charley thanks, it works!
            Maybe you can answer another question: when I close or open the screens with domotics, the icons changes ( and the text open- close) in my Magic Mirror screen but when I close or open the screens with the original remote the icon does not change on the MM screen, only on the domoticz screen.
            I hope my question is clear enough.
            Peter
              Hello Peter,
              There are two different things. One is Domoticz and the other is MagicMirror.
              The module requests data from Domoticz. It is a reply in json.
              This comes from my shutter.
                       "AddjMulti" : 1.0,
                       "AddjMulti2" : 1.0,
                       "AddjValue" : 0.0,
                       "AddjValue2" : 0.0,
                       "BatteryLevel" : 255,
                       "CustomImage" : 0,
                       "Data" : "Open",
                       "Description" : "",
                       "DimmerType" : "abs",
                       "Favorite" : 0,
                       "HardwareID" : 7,
                       "HardwareName" : "ZwaveUSB",
                       "HardwareType" : "OpenZWave USB",
                       "HardwareTypeVal" : 21,
                       "HaveDimmer" : true,
                       "HaveGroupCmd" : true,
                       "HaveTimeout" : false,
                       "ID" : "00000501",
                       "Image" : "Light",
                       "IsSubDevice" : false,
                       "LastUpdate" : "2018-04-16 08:37:09",
                       "Level" : 255,
                       "LevelInt" : 255,
                       "MaxDimLevel" : 100,
                       "Name" : "Rolluik",
                       "Notifications" : "false",
                       "PlanID" : "7",
                       "PlanIDs" : [ 7 ],
                       "Protected" : false,
                       "ShowNotifications" : true,
                       "SignalLevel" : "-",
                       "Status" : "Open",
                       "StrParam1" : "",
                       "StrParam2" : "",
                       "SubType" : "Switch",
                       "SwitchType" : "Blinds Inverted",
                       "SwitchTypeVal" : 6,
                       "Timers" : "true",
                       "Type" : "Light/Switch",
                       "TypeImg" : "blinds",
                       "Unit" : 1,
                       "Used" : 1,
                       "UsedByCamera" : false,
                       "XOffset" : "698",
                       "YOffset" : "1168",
                       "idx" : "31"
              The Image in this record is not the image in the MagicMirror. The MagicMirror Icons are from Fontawesome version 4.7 there is now a version 5 available but doesn’t like to work along 4.7 in MagicMirror.
              The icons you see in my module are based on the type of device retrieved with the json file from Domoticz. See the lines in my code from 55 to line 71
              There are no icons for shutters/shades or similar in fontawesome. That is why I use the status text from Domoticz. (In the Netherlands the webinterface is in Dutch but you will see that the status of the blinds are in English)
              Hope this clarifies the icon issue.
                Updated today with Humidity and the possibility to not show the subMenus.
                I choose not to add the Barometric Pressure and Sound Levels from Netatmo because my screen would be high enough in portrait mode.
                  jaminben
                  Hi Charley,
                  I’m a newbie to MM so excuse me if the answer is obvious… the temperature and humidity work correctly but is there a way to display one after the other for the same sensor… so in my example screenshot you can see it lists all the temperatures first and then the humidity readings.
                  Anyway, many thanks for creating the module… it’s fantastic :)
                    @jaminben Thanks for the thank you, i am still working on it to make it better.
                    You can add more in your config.js settings
                          showItems: ['temperature','energy','battery','co', 'blinds','humidity','baro'],   // possible items  temperature, energy, battery, co, blinds, humidity,  baro
                    Could you please reply with your config settings for this module .(delete any personal information ip,username or password)
                    I think I misread your question, however all sensors data are grouped in the newest version.
                    J 1 Reply Last reply
                      jaminben @Charley
                      @Charley said in MMM-Domiticz:
                      @Charley
                      My config.js file…
                      /* Magic Mirror Config Sample
                       * MIT Licensed.
                      var config = {
                      	port: ******,
                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "********"], // Set [] to allow all IP addresses
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_left"
                      			header: "*******",
                      						symbol: "calendar-check-o ",
                      						url: "********"
                      			module: "compliments",
                      			position: "lower_third"
                      			module: "currentweather",
                      				locationID: "*****",  //ID from http://www.openweathermap.org/help/city_list.txt
                      				appid: "******"
                      			module: "weatherforecast",
                      			header: "Weather Forecast",
                      				locationID: "*******",  //ID from http://www.openweathermap.org/help/city_list.txt
                      				appid: "*****"
                      			module: "newsfeed",
                      			position: "bottom_bar",
                      				feeds: [
                      						title: "BBC News",
                      						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                      				showSourceTitle: true,
                      				showPublishDate: true
                      			module: "MMM-Domoticz",
                      			position: "top_right",   // see mirror setting for options
                      				updateInterval: 45, // every 45 seconds
                      				apiBase: '******',
                      				apiPort: ****,
                      				apiUser: "*******",
                      					apiPw: "********",
                      				temperatureTitle: "Current House Temperatures",
                      				moduleTitle: "My smart home by Domoticz",
                      				energyTitle: "Energy used by",
                      				batteryTitle: "Battery level",
                      				coTitle: "CO2 level",
                      				blindsTitle: "Blinds",
                      				energyNow: "Currently",
                      				energyTotal: "Energy used",
                      				batteryThreshold: 20,
                      						coThreshold: 650,
                      				subMenus: true,
                      				showItems: ['temperature'],   // possible items  temperature, energy
                      				excludedDevices: ['none','add your own']  // Device that will not be shown
                      			module: 'MMM-Todoist',
                      			position: 'top_right',	// This can be any of the regions. Best results in left or right regions.
                      			header: 'Todoist', // This is optional
                      			config: { // See 'Configuration options' for more information.
                      				accessToken: '********',
                      				maximumEntries: 60,
                      				updateInterval: 10*60*1000, // Update every 10 minutes
                      				projects: [ 166564794 ],
                      				fade: false
                      What I was trying to was something like:
                      Garden 24.1 (temperature)
                      55% (humidity)
                      Lounge 20.2 (temperature)
                      45% (humidity)
                      Garage 22.1 (temperature)
                      48% (humidity)
                      Rather than:
                      Garden 55% (humidity)
                      Lounge 45% (humidity)
                      Garage 48% (humidity)
                        jaminben
                        @Charley
                        I just updated to the new version and it only shows the temperature now… not sure if that was intended or not.
                          You need to add humidity and baro to the showItems part in config.js
                          to see all options (someone asked in PM to block humidity)
                          It will now show the way you like it
                            jaminben @Charley
                            @Charley
                            Very cool… can I make one suggestion? How about if it detects that it already has a name present for the temperature it doesn’t display the name for the humidity and/or baro just the value? That way you don’t get duplicate names for the same sensor.
                            I can see in yours you have Woonkamer (Living Room) repeated 3 times which I assume is the same sensor?
                              Yes they are all the same sensor. I will try in the coming days if I am able to get those properly.
                              Just made it. if you pull the upgrade it is there
                                jaminben @Charley
                                Very nice… it works as expected :)
                                Next request… is there a way to sort them some how?
                                Sorry, I know I’m a PITA.
                                  jaminben @jaminben
                                  @Charley
                                  Ah, no… ignore my last comment. I can sort them via my Domoticz Dashboard.
                                  Once again, MANY THANKS… I really appreciate the work you’ve done.
                                  Very Cool Stuff.
                                    @jaminben
                                    I already tried before to reorder the data. In the description of API/JSON for Domoticz it says you can order by Name. (Line 37 in my code)
                                    That is the documentation, but in reality you can’t order anything. If I look in the json coming from the request file there are no objects that would follow the order in your webapplication.
                                    It could be done my making an array where all sensors are switches are in, but it would be a hassle if you add a new device you would also need to add to your modules config.
                                    Lets wait what the next version of Domoticz brings and if I am able to implement it.
                                      jaminben @Charley
                                      @jaminben
                                      Not sure if you saw my previous comment and I’m not sure if it’s a fluke but I re-ordered my sensors within my Domoticz dashboard and they automatically re-ordered themselves within your module on the MM to match… probably a coincidence but mines looking exactly how I want them :)
                                        @jaminben Thanks I will arrange them in my Dashboard as well.
                                          Today added total actual usage of Watts.
                                          Please add ‘usage’ to your showItems in your config.js
                                            jaminben
                                            Hi Charley,
                                            Is it possible to get the colour of the values and icons to be white rather than grey?
                                            Ben
                                            • 2 / 4
