    MMM-Domiticz
    68 Posts 18 Posters 61.4k Views 18 Watching
      Peter
      Maybe a stupid question; do I have to make the changes in MM config.js file or in Domoticz.js file?
      Peter
        Charley Module Developer
        @Peter there are no stupid questions
        You should make the changes in the MagicMirror config.js file, if you make them in the MMM-Domoticz.js they will be gone in the next updates.
        In the MMM-Domoticz.js that are the default values if you don’t put it in the MM config.js file the value from the module will be used.
        Good luck
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          Peter
          Sorry, Charley, I deleted Domoticz folder, installed again and now I have a problem:
          How can I solve this?
          Peter
            @peter
            I am sorry this happend. i flip the screen if you have the app on the left side. the L should point the otherway as well. I try to fix it on monday or tuesday. However is quick fix is putting the module op the right side in the config
            P 1 Reply Last reply
              Peter @Charley
              @Charley thanks.
              I will wait for the fix!
              No hurry.
              Peter
                @Peter made an update this morning.
                The grouping must be set now and is not a default.
                If you like the same sensor with different values grouped add
                groupSensors: true
                To config.js for the module and the sensors will be grouped. However if the module is placed on a left position the hook └─ (right) ─┘(left) sometimes shows unexpected behavior.
                  To make the Domoticz System better I have made a WiFi Thermometer that is extremely precise. It is based on an infrared Non-touch sensor module. If you want to control devices this may be a good solution.
                  Available on gitHub WiFi highly precise thermometer
                    DavA
                    I cant see anything but temperature? No status on switches ON or OFF.
                    Also is it possible to not show all my temperature-sensors?
                      It shows only devices at are switched on.
                        Smotx
                        Thx for this module.
                        How to exclude Xiaomi doors sensors ?
                        Thx for help.
                        C 1 Reply Last reply
                          Today added support for p1 Smart meters
                          first update your module
                          cd MagicMirror/modules/MMM-Domoticz
                          git pull
                          pm2 restart MagicMirror
                          Add these 2 lines to the config file
                          smartMeter:  true,
                          smartMeterOffset: 0
                          You may need a commy behind the 0 from smartMeterOffset
                          The offset you use if the meter wasn’t zero when you moved in or if you want to show total per year of month
                            Charley Module Developer @Smotx
                            @Smotx
                            excluding can be done by adding the device names in the excludeDevices array in your config.js file
                            • A
                              Awn
                              First of all, thank you for the hard work on those modules.
                              I’m nex to the MM world, and in the linux world in global, and it seems that I won’t be able to make it without your help.
                              The module shows “Loading Domoticz data…” and seems to never get them…
                              My config.js contains this :
                                                      module: "MMM-Domoticz",
                                                      position: "bottom_right",
                                                      config:
                                                              updateInterval: 20,
                                                              apiBase: "https://192.168.**.***",
                                                              apiPort: 443,
                                                              apiUser: "**********",
                                                              apiPw: "*********",
                                                              moduleTitle: "Domoticz",
                                                              temperatureTitle: "Températures dans la maison",
                                                              subMenus: true,
                                                              showItems: ['temperature', 'humidity'],
                                                              textWhite: false,
                                                              groupSensors: true,
                              Sadly, it seems that the pi running the MM isn’t getting an answer from the pi running Domoticz.
                              I tried the url access from my browser:
                              https://192.168..*/json.htm?type=devices&filter=all&used=true&order=Name
                              I obtain a return with the different systems connected (RFXCom, Zwave, hue…)
                              Can somebody guide me throught this please?
                              Thanx !
                              Regards,
                              Awn
                                Pl4nk
                                  sdetweil @Awn
                                  @Awn on the magicmirror, using the keyboard, open the developers window, ctrl-shift-i,
                                  select the tab labeled console, on the window that opens, scroll up to see any errors
                                  u may also have to look in the terminal window log for errors from the node_helper
                                  these will be in the pm2 logs if using pm2.
                                  do
                                  pm2 logs --lines=100
                                    Jo-Rien
                                    I am not getting a neat list with this module, all readings from my temperature meters is shown on two lines and it’s kinda messing up the screen. Any idea what the problem is?
                                    • T
                                      ToniNappi
                                      Is it possible also exclude sensors from the displayed data? I have about 50 temp sensors and obviously I want only see the most important ones. I tried to put them in exlude list, but it doesn’t seem to work. Nice module still!
                                      Toni
                                      • N
                                        najtram
                                        Hi, there.
                                        Great module!
                                        It’s passing the described data perfectly except one of my top desired data.
                                        I’d really love to see “CounterToday” and “Data” from my Enphase Envoy.
                                        Since this is a kWh subtype it looks like I’m really close, but somehow I only see my P1 data.
                                             "AddjMulti" : 1.0,
                                             "AddjMulti2" : 1.0,
                                             "AddjValue" : 0.0,
                                             "AddjValue2" : 0.0,
                                             "BatteryLevel" : 255,
                                             "CounterToday" : "0.117 kWh",
                                             "CustomImage" : 0,
                                             "Data" : "486.173 kWh",
                                             "Description" : "",
                                             "Favorite" : 0,
                                             "HardwareID" : 9,
                                             "HardwareName" : "Enphase Envoy",
                                             "HardwareType" : "Enphase Envoy with LAN (HTTP) interface",
                                             "HardwareTypeVal" : 108,
                                             "HaveTimeout" : false,
                                             "ID" : "00000901",
                                             "LastUpdate" : "2020-09-13 08:31:50",
                                             "Name" : "Enphase kWh Production",
                                             "Notifications" : "false",
                                             "Options" : "",
                                             "PlanID" : "0",
                                             "PlanIDs" : [ 0 ],
                                             "Protected" : false,
                                             "ShowNotifications" : true,
                                             "SignalLevel" : "-",
                                             "SubType" : "kWh",
                                             "SwitchTypeVal" : 0,
                                             "Timers" : "false",
                                             "Type" : "General",
                                             "TypeImg" : "current",
                                             "Unit" : 1,
                                             "Usage" : "280 Watt",
                                             "Used" : 1,
                                             "XOffset" : "0",
                                             "YOffset" : "0",
                                             "idx" : "748"
                                          Sp0nsje
                                          Hi thanks for the great work,
                                          Is there a better guide on how to implement certain sensors ?
                                          like an ‘‘IDX xx’’ value or something
        position: "bottom_right",   // see mirror setting for options
        updateInterval: 5, // every 45 seconds
        apiBase: "192.168.178.44",
        apiPort: 18080,
        apiUser: "MagicMirror",
        apiPw: "MagicMirror",
        moduleTitle: "My smart home by Domoticz",
        energyTitle: "Energy used by",
        batteryTitle: "Battery level",
        coTitle: "CO2 level",
        blindsTitle: "Blinds",
        energyNow: "Currently using",
        energyTotal: "Energy used",
        energyToday: "Energy used today",
        batteryThreshold: 20,
        coThreshold: 650,
        subMenus: true,
        smartMeter: false,
        smartMeterOffset: 0,
        showItems: ['temperature'], //,'energy','battery','co','blinds','humidity','baro','usage','voltage','alarm','sensor','pulse','meter','rain'],
        excludeDevices: ['none','include your own'],  // Device that will not be shown
        onlyShowExcluded: false, // if true only exluded devices are shown
        textWhite: true,
        alarmOffLabel: "Disabled",
        groupSensors: false,
                                          i can only show the temperatures when i select al the data it wil hang on Loading Domoticz Data…
                                          would appriciate different screenshots of codes / layouts on the MM2
                                            Mazzokun
                                            I think there is something broken into code or there is some dependence-package with raspberryOs…
                                            In Domoticz I have 30+ devices and In MM shows only a meter device with 0,0,0 values ( I have 3 meter device, no possible value)…
                                            If I try open the json url into chromium it says error 401 forbidden, but if I try the same url into Mac safari it simple works.
                                            Any Idea?
                                            M 1 Reply Last reply
                                            • 3 / 4
