    MMM-Domiticz
    68 Posts 18 Posters 58.9k Views 18 Watching
      DavA
      I cant see anything but temperature? No status on switches ON or OFF.
      Also is it possible to not show all my temperature-sensors?
        Charley Module Developer
        It shows only devices at are switched on.
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          Smotx
          Thx for this module.
          How to exclude Xiaomi doors sensors ?
          Thx for help.
            Today added support for p1 Smart meters
            first update your module
            cd MagicMirror/modules/MMM-Domoticz
            git pull
            pm2 restart MagicMirror
            Add these 2 lines to the config file
            smartMeter:  true,
            smartMeterOffset: 0
            You may need a commy behind the 0 from smartMeterOffset
            The offset you use if the meter wasn’t zero when you moved in or if you want to show total per year of month
              Charley Module Developer @Smotx
              @Smotx
              excluding can be done by adding the device names in the excludeDevices array in your config.js file
                Awn
                First of all, thank you for the hard work on those modules.
                I’m nex to the MM world, and in the linux world in global, and it seems that I won’t be able to make it without your help.
                The module shows “Loading Domoticz data…” and seems to never get them…
                My config.js contains this :
                                        module: "MMM-Domoticz",
                                        position: "bottom_right",
                                        config:
                                                updateInterval: 20,
                                                apiBase: "https://192.168.**.***",
                                                apiPort: 443,
                                                apiUser: "**********",
                                                apiPw: "*********",
                                                moduleTitle: "Domoticz",
                                                temperatureTitle: "Températures dans la maison",
                                                subMenus: true,
                                                showItems: ['temperature', 'humidity'],
                                                textWhite: false,
                                                groupSensors: true,
                Sadly, it seems that the pi running the MM isn’t getting an answer from the pi running Domoticz.
                I tried the url access from my browser:
                https://192.168..*/json.htm?type=devices&filter=all&used=true&order=Name
                I obtain a return with the different systems connected (RFXCom, Zwave, hue…)
                Can somebody guide me throught this please?
                Thanx !
                Regards,
                Awn
                  Pl4nk
                    sdetweil @Awn
                    @Awn on the magicmirror, using the keyboard, open the developers window, ctrl-shift-i,
                    select the tab labeled console, on the window that opens, scroll up to see any errors
                    u may also have to look in the terminal window log for errors from the node_helper
                    these will be in the pm2 logs if using pm2.
                    do
                    pm2 logs --lines=100
                      Jo-Rien
                      I am not getting a neat list with this module, all readings from my temperature meters is shown on two lines and it’s kinda messing up the screen. Any idea what the problem is?
                      • T Offline
                        ToniNappi
                        Is it possible also exclude sensors from the displayed data? I have about 50 temp sensors and obviously I want only see the most important ones. I tried to put them in exlude list, but it doesn’t seem to work. Nice module still!
                        Toni
                        • N Offline
                          najtram
                          Hi, there.
                          Great module!
                          It’s passing the described data perfectly except one of my top desired data.
                          I’d really love to see “CounterToday” and “Data” from my Enphase Envoy.
                          Since this is a kWh subtype it looks like I’m really close, but somehow I only see my P1 data.
                               "AddjMulti" : 1.0,
                               "AddjMulti2" : 1.0,
                               "AddjValue" : 0.0,
                               "AddjValue2" : 0.0,
                               "BatteryLevel" : 255,
                               "CounterToday" : "0.117 kWh",
                               "CustomImage" : 0,
                               "Data" : "486.173 kWh",
                               "Description" : "",
                               "Favorite" : 0,
                               "HardwareID" : 9,
                               "HardwareName" : "Enphase Envoy",
                               "HardwareType" : "Enphase Envoy with LAN (HTTP) interface",
                               "HardwareTypeVal" : 108,
                               "HaveTimeout" : false,
                               "ID" : "00000901",
                               "LastUpdate" : "2020-09-13 08:31:50",
                               "Name" : "Enphase kWh Production",
                               "Notifications" : "false",
                               "Options" : "",
                               "PlanID" : "0",
                               "PlanIDs" : [ 0 ],
                               "Protected" : false,
                               "ShowNotifications" : true,
                               "SignalLevel" : "-",
                               "SubType" : "kWh",
                               "SwitchTypeVal" : 0,
                               "Timers" : "false",
                               "Type" : "General",
                               "TypeImg" : "current",
                               "Unit" : 1,
                               "Usage" : "280 Watt",
                               "Used" : 1,
                               "XOffset" : "0",
                               "YOffset" : "0",
                               "idx" : "748"
                            Sp0nsje
                            Hi thanks for the great work,
                            Is there a better guide on how to implement certain sensors ?
                            like an ‘‘IDX xx’’ value or something
                                                    position: "bottom_right",   // see mirror setting for options
                                                            updateInterval: 5, // every 45 seconds
                                                            apiBase: "192.168.178.44",
                                                            apiPort: 18080,
                                                            apiUser: "MagicMirror",
                                                            apiPw: "MagicMirror",
                                                            moduleTitle: "My smart home by Domoticz",
                                                            energyTitle: "Energy used by",
                                                            batteryTitle: "Battery level",
                                                            coTitle: "CO2 level",
                                                            blindsTitle: "Blinds",
                                                            energyNow: "Currently using",
                                                            energyTotal: "Energy used",
                                                            energyToday: "Energy used today",
                                                            batteryThreshold: 20,
                                                            coThreshold: 650,
                                                            subMenus: true,
                                                            smartMeter: false,
                                                            smartMeterOffset: 0,
                                                            showItems: ['temperature'], //,'energy','battery','co','blinds','humidity','baro','usage','voltage','alarm','sensor','pulse','meter','rain'],
                                                            excludeDevices: ['none','include your own'],  // Device that will not be shown
                                                            onlyShowExcluded: false, // if true only exluded devices are shown
                                                            textWhite: true,
                                                            alarmOffLabel: "Disabled",
                                                            groupSensors: false,
                            i can only show the temperatures when i select al the data it wil hang on Loading Domoticz Data…
                            would appriciate different screenshots of codes / layouts on the MM2
                              Mazzokun
                              I think there is something broken into code or there is some dependence-package with raspberryOs…
                              In Domoticz I have 30+ devices and In MM shows only a meter device with 0,0,0 values ( I have 3 meter device, no possible value)…
                              If I try open the json url into chromium it says error 401 forbidden, but if I try the same url into Mac safari it simple works.
                              Any Idea?
                                MisterT @Mazzokun
                                Hi @Mazzokun
                                I had a problem with this module and with the help of @sdetweil a New code is available here. It works with domoticz password
                                [link text] https://forum.magicmirror.builders/topic/11123/mmm-domoticz-cannot-read-property-0-of-undefined/13?page=2
                                (link url)
                                Enjoy
                                  art212
                                  Hi, Are Domoticz and Magic Mirror installed on one Raspberry Pi? Are they two separate?
                                    MisterT @art212
                                    @art212 Domoticz and Magic mirror are separate. In the config.js, just complete the Ip adress of Domoticz Device and Domoticz user and password if need. In my case, Domoticz is on a raspberry and my magic mirror on a other one
                                    A 1 Reply Last reply Reply Quote 1
                                      art212 @MisterT
                                      @MisterT Ok thanks for the answer. What do you think? Is it possible to run MM and Domoticz together on one Raspberry Pi machine? Because I have a big problem with that. Domoticz is showing me instead of MM. I have to uninstall one for the other to work well …
                                        MisterT @art212
                                        @art212 i think it’s possible to run domoticz ans MM on the same raspberry. On terminal, if you write this command line, does domoticz appears on screen ?
                                        Sudo service domoticz restart
                                        If not domoticz is on but in background and You Can start MM with pm2
                                          Mazzokun @MisterT
                                          @MisterT Hi! I tried your code but it doesn’t work… in which folder in domoticz folder I have to copy the script?
                                          ty
                                            MisterT @Mazzokun
                                            @Mazzokun this command line is just for restart domoricz There is no link directly with magic mirror
                                            The command line in terminal (Home/pi/)
                                            Sudo service domoticz.sh status
                                            Just to know if domoticz is on or off
                                            Sudo service domoticz.sh restart
                                            Just to stop and start again domoticz
                                            Follow this link to start domoticz when raspberry boot
                                            https://www.domoticz.com/wiki/Linux
                                            And chapter
                                            Starting Domoticz automatically when the system boots
                                            • 3 / 4
