    MMM-crypto-portfolio
    26 Posts 12 Posters 12.8k Views 11 Watching
    • PowellaJasonP Offline
      PowellaJason
      Ammetto, sono un trader alle prime armi e non so da che parte muovermi. Ho iniziato per gioco ma mi piacerebbe sviluppare le mie conoscenze fidandomi e affidandomi a qualcuno di specializzato. Mio cognato intanto mi ha fatto andare sulla piattaforma di FBS broker e ne sono rimasto colpito. Seminari gratuiti, interfaccia utente personalizzata e la possibilità di parlare con chi se ne intende per davvero. Penso proprio che continuerò su questa linea.
        duxnobis
        I know it’s been a while since this was used last time but I decided to give it a try. Where can I find this module?
          duxnobis @duxnobis
          @duxnobis Found the module, but even using the demo config entry it does not show up but give me an error on the mirror. Anyone info about if this still works?
          • iMAGiCI Offline
            iMAGiC @Charley
            @charley this repo is cool, and I’ve added into my mirror for while.
            I don’t know if you are farming Chia (Chia Network), Chia has many forks there, many farmer farming many forks at the same time on the same machine, that cause not easy to check their wallet and cold wallet also.
            I found an APP on Google store that can track all your wallet via “network browser” ex.https://alltheblocks.net/ , user can add all different fork wallets, it’s very easy get an update via a swipe down on mobile phone screen.
            Is possible that you combine your repo and create a new one that similar as Chiew ?
            so that MM user can see updated wallets amount every 15mins or 30mins.
            iMAGiC
            Choice * Judgment * Values
            • F Offline
              fischi87
              Hello, I install ur module and just copy and paste ur config from the readme but I get just a header with ‘my crypto portfolio’ and nothing more. is this module just update? or what I did wrong?
              thanks
              MarosM 1 Reply Last reply Reply Quote 0
              • MarosM Offline
                Maros @fischi87
                Is it possible to add to this API from Helium network ? so i will be able to see current amount in my helium wallet ?
                I don’t want to manually write amount as this is changing.
                I tried to search modules but i don’t see any suitable module.
                Maybe edit MMM-Coinbase module to show only Helium wallet from (explorer.helium.com)
                • 3 / 3
