    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 46.4k Views 10 Watching
      bitfit2020
      U da man!!! I’m back on the playground :) Thanks.
        bitfit2020
        Must be some of my modules but with your default config mirror works but with my config I get a BLACK SCREEN.
        BTW, I did not upgrade (was a bit worried)… not sure if should do that !
          sdetweil @bitfit2020
          @bitfit2020 it gives u that control
          but glad u got it working
            @bitfit2020 i dont have a config in any of my scripts
            i used the sample doing install,
            config.js for upgrade
            and no confug for the screen saver and pm2 scripts at the end
            upgrade does what u are supposed to do manually, but breaks running systems with lots of none-base modules
            upgrade tries to detect and fix the breakage
            run 1st time it will just check if its possible upgrade would work
            second time with ‘apply’ parm will do the upgrade process. a log is kept of the process
            • 6
            • 6 / 6
