    MM installation error by electron / arm64
    2 Posts 2 Posters 1.7k Views 2 Watching
    • L
      linuxni
      I’m sorry first.
      I do not speak English well.
      That’s why we use google translation.
      I first installed MM on the artik 530 and odroid ux4.
      The MM installation succeeded and worked well on these two devices.
      But I tried to install MM again in artik 710s, but I can not …
      In the same way, I installed ubuntu 16.4 server on VMware workstation and MM is working.
      I think the artik 710s is due to arm64.
      [root@artik MagicMirror]# grep . /etc/*-release
      /etc/lsb-release:DISTRIB_ID=Ubuntu
      /etc/lsb-release:DISTRIB_RELEASE=16.04
      /etc/lsb-release:DISTRIB_CODENAME=xenial
      /etc/lsb-release:DISTRIB_DESCRIPTION="Ubuntu 16.04.4 LTS"
      /etc/os-release:NAME="Ubuntu"
      /etc/os-release:VERSION="16.04.4 LTS (Xenial Xerus)"
      /etc/os-release:ID=ubuntu
      /etc/os-release:ID_LIKE=debian
      /etc/os-release:PRETTY_NAME="Ubuntu 16.04.4 LTS"
      /etc/os-release:VERSION_ID="16.04"
      /etc/os-release:HOME_URL="http://www.ubuntu.com/"
      /etc/os-release:SUPPORT_URL="http://help.ubuntu.com/"
      /etc/os-release:BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
      /etc/os-release:VERSION_CODENAME=xenial
      /etc/os-release:UBUNTU_CODENAME=xenial
      [root@artik MagicMirror]# uname -m
      aarch64
      [root@artik MagicMirror]# getconf LONG_BIT
      64
      [root@artik MagicMirror]# dpkg -s libc6 | grep Arch
      Architecture: arm64
      Multi-Arch: same
      [root@artik MagicMirror]# npm -v
      5.8.0
      [root@artik MagicMirror]# node -v
      v8.11.1
      [root@artik MagicMirror]# npm install
      > electron-chromedriver@1.7.1 install /root/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      /root/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver/download-chromedriver.js:16
        if (error != null) throw error
      Error: Failed to find Electron v1.7.0 for linux-arm64 at https://github.com/electron/electron/releases/download/v1.7.0/chromedriver-v1.7.0-linux-arm64.zip
          at Request. (/root/MagicMirror/node_modules/nugget/index.js:169:61)
          at emitOne (events.js:116:13)
          at Request.emit (events.js:211:7)
          at Request.onRequestResponse (/root/MagicMirror/node_modules/request/request.js:1068:10)
          at ClientRequest.emit (events.js:211:7)
          at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:551:21)
          at HTTPParser.parserOnHeadersComplete (_http_common.js:115:23)
          at TLSSocket.socketOnData (_http_client.js:440:20)
      npm WARN grunt-stylelint@0.10.0 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! electron-chromedriver@1.7.1 install: `node ./download-chromedriver.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron-chromedriver@1.7.1 install script.
      npm ERR!     /root/.npm/_logs/2018-04-05T06_42_45_454Z-debug.log
      https://github.com/electron/electron/releases/tag/v1.7.0
      When I checked here, I could not find the arm64.
      My simple idea is that you do not have https://github.com/electron/electron/releases/download/v1.7.0/chromedriver-v1.7.0-linux-arm64.zip
      https://github.com/electron/electron/releases/tag/v1.8.0
      There is an arm64 file since version 1.8.
      I want to modify it to be installed with electron 1.8 or later version, but I do not know how.
      help me plz
      • C
        cptnclvn
        Did you ever fix this? I am running into the same issue.
