    Connection refused (http)
    3 Posts 2 Posters 4.7k Views 2 Watching
    • C Offline
      CFenner
      Hey mirror user,
      my mirror is running for quite some time. Meanwhile I moved and have a new wifi setup. Anyhow today I wanted to work on the plugins again and I wasn’t able to connect to the mirror (http, ssh works).
      First I thought it where the whitelist settings and I adjusted them. But I simply get a Failed to connect to 192.168.178.65 port 8080: Connection refused with curl, no message from the mirror at all.
      If I ssh to the mirror I can curl from the to localhost:8080 and it works all fine, but also from the pi itself curl 192.168.178.65:8080 doesn’t work.
      Any idea what might be the issue here? I don’t know what to do (in german “ich bin am Ende mit meinem Latein”).
      Could this be an issue of DNS or the PI?
      Best regards
      Christopher
      • C Offline
        CFenner
        Seems do be the magic mirror config :( I need to specify the ip in the config (“address”) to be accessible.
        • Krato5K Offline
          Krato5
          @CFenner said in Connection refused (http):
          of DNS or
          just whitelist your IPadress or see if youre behind a firewall , you can follow these instructures !
          https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto
