    PLEASE HELP. Error: read ECONNRESET at TLSWrap.onread (net.js:602:25)
    1 Posts 1 Posters 1.9k Views 1 Watching
    • T Offline
      trance border
      tried to run the bash command and the installation got stucked to this message
      can you guys help me step by step?
      I HAVE NO IDEEA ABOUT PROGRAMMING AND A STEP BY STEP TUTORIAL WILL SAVE MY LIFE.
      THANK YOU VERY MUCH
      **Cloning into 'MagicMirror'...
      remote: Counting objects: 277, done.
      remote: Compressing objects: 100% (246/246), done.
      remote: Total 277 (delta 37), reused 121 (delta 21), pack-reused 0
      Receiving objects: 100% (277/277), 421.09 KiB | 554.00 KiB/s, done.
      Resolving deltas: 100% (37/37), done.
      Cloning MagicMirror Done!
      Installing dependencies ...
      > uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
      > node-gyp rebuild > build_log.txt 2>&1 || exit 0
      > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      > electron@1.7.13 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      /home/pi/MagicMirror/node_modules/electron/install.js:48
        throw err
      npm WARN grunt-stylelint@0.10.0 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! electron@1.7.13 postinstall: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron@1.7.13 postinstall script.
      npm ERR!     /home/pi/.npm/_logs/2018-04-15T23_48_40_173Z-debug.log
      pi@raspberrypi:~ $**
