    iCloud calendar
    5 Posts 2 Posters 7.7k Views 2 Watching
      blebbens
      Hi there,
      At the moment my family is using Apple iClound calendar (family sharing). Now I would like to show this calendar on my mirror‘s screen.
      As this iCloud does not have an URL, I wanted to sync the content to gmail calendar. But, I did not find an automatically syncing solution.
      Next idea was to use IFTTT, but this only works for new appointments.
      I don‘t want to do this manually using Windows/macOS?
      Is there a way to show iCloud calendar under MagicMirror?
      tbbearT 1 Reply Last reply Reply Quote 0
      • tbbearT Offline
        tbbear Module Developer @blebbens
        @blebbens HI, of course iCloud has an url go to ur iCloud and set ur calender to public. It will give u an url that u can us for ex. in MMM-MyCalendar module. I do this since long time. The config will look like this:
                module: "MMM-MyCalendar",
                header: "Wos gibts?",
        	maximumEntries: 2,
                config:
                  colored: true,
                  calendars:
                      /* Geburtstage von fb ok */
                      symbol: "birthday-cake",
                      color: "#82E5AA",
                      url: "webcal://www.facebook.com/ical/xxxxxxxxxxxxxxxxxx"
                      /* Familie ok */
                      symbol: "female",
                      color: "yellow",
                      url: "webcal://p27-calendars.icloud.com/published/xxxxxxxx"
                      /* Roberts Kalender */
                      symbol: "calendar",
                      url: "https://p05-calendars.icloud.com/published/xxxxxxxx"
                      /* Feiertage ok */
                      symbol: "calendar-check-o",
                      color: "green",
                      url: "webcal://p05-calendarws.icloud.com/ca/subscribe/1/xxxxxxxxxxx"
        of course i removed my real caledar data
        Robert the Bear
          blebbens
          Ok, public does not mean other people can access it, just people with the secret URL?
          Where did you set your family calendar public?
          Do you use 2 factor authentification?
          • tbbearT Offline
            @blebbens The answer is yes only with secret URL, U can do it on icloud.com with ur login and yes i use 2 factor
            Robert the Bear
              blebbens
              Thanks, it is working…
              But, I am wondering… I don´t need auth, because it is public…
              Thought, I have to set it public for accessing it with mm-modules ?
              Where do you use 2FA ?
