    Config.js not working
    4 Posts 2 Posters 2.1k Views 2 Watching
      Dandrea30
      Hi guys,
      I am able to get my magicmirror working with the standard config.js settings preinstalled, but when i then add aditional modules, the config file stops working.
      I have tried everything to get it running, but it fails to load.
      Could someone please review my config file and advise where i have gone wrong.
      All help appreciated
      /* Magic Mirror Config file
      • By Michael Teeuw http://michaelteeuw.nl
      • MIT Licensed.
      var config = {
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
      language: "en",
      timeFormat: 24,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "UK Holidays",
      					symbol: "calendar-check-o ",
      					url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
      		module: "compliments",
      		position: "lower_third"
      		module: "currentweather",
      			locationID: "2643097",  //ID from http://www.openweathermap.org/help/city_list.txt
      			appid: "1ff19eb375630ae2d015b49428d7cbec"
      		module: "weatherforecast",
      		header: "Weather Forecast",
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "Sky News",
      					url: "http://feed.skynews.com/feeds/rss/uk.xml"
      			showSourceTitle: true,
      			showPublishDate: true
                          module: 'MMM-Traffic',
                          position: 'bottom_right',
                          classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                                  api_key: 'your_apikey_here',
                                  mode: 'driving',
                                  origin: '4 Pennsylvania Plaza, New York, NY 10001',
                                  destination: '1 MetLife Stadium Dr, East Rutherford, NJ 07073',
                                  mon_destination: '116th St & Broadway, New York, NY 10027',
                                  fri_destination: '1 E 161st St, Bronx, NY 10451',
                                  arrival_time: '0800', //optional, but needs to be in 24 hour time if used.
                                  route_name: 'Home to Work',
                                  changeColor: true
                                  showGreen: false,
                                  limitYellow: 5, //Greater than 5% of journey time due to traffic
                                  limitRed: 20, //Greater than 20% of journey time due to traffic
                                  traffic_model: 'pessimistic'
                                  interval: 120000 //2 minutes
      if (typeof module !== “undefined”) {module.exports = config;}
      • N Offline
        NoNameRo @Dandrea30
        @dandrea30
        you’re missing a }
                                    mode: 'driving',
                                    changeColor: true
                                    showGreen: false,
          Dandrea30 @NoNameRo
          @nonamero thank you for your reply. I have edited the file as advised, but i still get the dread: Please Create a Config File.
          I have tried deleting the input and typing all manually, but to no avail.
          • N Offline
            NoNameRo @Dandrea30
            @dandrea30
            there are two commas missing
                                    mode: 'driving',
                                    changeColor: true,
                                    showGreen: false,
                                    traffic_model: 'pessimistic',
