    How to enable a 70" IR touch overlay to provide touch on a certain lesser size display?
    11 Posts 7 Posters 6.6k Views 7 Watching
      danil
      My IR touch overlay size is 70 inch and the display I am using is 43 inch. Since the overlay comes on top of the mirror, and the size of the mirror is 70 inch, is there any way to configure a 70 inch IR overlay to provide touch support only on the 43 inch size display I am using??
      How to fix this problem???
      • E Offline
        E3V3A
        Would be nice to know this too…
        "Everything I do (here) is for free – altruism is the way!"
        MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
        • joela85J Offline
          joela85
          Interesting, I have been looking at buying the correct size overlay for my project. I’ve found larger ones cheaper which is annoying. I’ve been wondering if it’s possible to re-calibrate the overlay to a smaller screen?
          peemoellerP 1 Reply Last reply Reply Quote 0
          • C Offline
            cyberphox
            wondering as well…i have a spare 50" IR frame to use with a 40" lcd tv.
            • peemoellerP Offline
              peemoeller @joela85
              @joela85 Hi, wondering if you learned a solution for this? I just managed to get my 42 inch IR Touch Overlay set to portrait on my MM. I have a 32 inch LCD monitor for this project.
              Where can I set or adjust this? Any thoughts?
              joela85J 1 Reply Last reply Reply Quote 0
              • joela85J Offline
                joela85 @peemoeller
                @peemoeller Hi, I never went down this route in the end. It might still be something I might try in the future.
                In the end I found a cheap good quality 24" monitor which was going to be fine for my project.
                I found some tutorials somewhere on calibrating a touch display but hadn’t found anything with about calibrating for a smaller monitor.
                Have you tried experimenting with normal calibration to see if it will calibrate to a smaller display?
                I’d be interested if you find a solution to this as I might well be tempted to try it in the future.
                • C Offline
                  cyberphox
                  FYI: i found out in Windows its just a matter of running the calibration software for your IR touch monitor…sorry to bump an old thread but in case someone was searching for an answer
                  • cowboysdudeC Offline
                    cowboysdude Module Developer
                    Yes that is a software for the touchframe that needs to be run…nothing you can run in MagicMirror to make it work. I basically bought a 32" TV and a 32" Frame…
                    • C Offline
                      cyberphox @cowboysdude
                      @cowboysdude hey man! long time no talk! I bought a 24" touchscreen monitor for the family info board and finally figured out how to keep the rotated touch settings when it goes to sleep. Can’t wait to mount it!
                      Hope your screen is going well!
                      • Y Offline
                        yns117 @cyberphox
                        @cyberphox Hi phox I am in the same trouble as you. I can not adapt my IR xintai touch (65 “) with my tv 55”. :( I think i need a software for set this ?
