    MMM-CTA 2nd Instance Not Automatically Updating
    3 Posts 1 Posters 1.2k Views 1 Watching
      Sitm09
      I am running 2 instances of MMM-CTA. I updated the second instance config to module Instance: 2, as shown below:
      module: “MMM-CTA”,
      position: “top_middleleft”,
      updateTime: 60000, // 1 minute, no need to go below
      ctaApiKeyTrain: “bc9d0610109c4f4bba82e89bb6968777”,
      trainStopName: ‘Wellington’,
      trainStationID: ‘41210’,
      maxResultTrain: 4,
      moduleInstance: 1, // To run multiple instances of this module
      		module: "MMM-CTA",
      		position: "top_middleright",
      			updateTime: 60000,
      			ctaApiKeyTrain: "bc9d0610109c4f4bba82e89bb6968777",
      			trainStopName: 'Belmont',
      			trainStationID: '41320',
      			maxResultTrain: 6,
      			moduleInstance: 2,
      The first instance (on the left) will update while the second (right) will not automatically update after 1 minute. Thank you for any help.
      P.S. Apologize for the excessively large image.
        Sitm09
        If this helps, this is the output when I run node serveronly. In the red, you can see the 1st instance of the 4 stops being loaded (red arrow) upon startup along with the second instance loading the 6 (blue arrow).
        After the 60 seconds, you see the 1st instance updating and a minute after updating again. However, this is not done for the 2nd instance.
          Sitm09 @Sitm09
          Fixed the issue. A description of said fix can be seen here:
          https://github.com/NateDee/MMM-CTA/issues/3
