    MMM-hass
    2 Posts 2 Posters 1.6k Views 2 Watching
    • F
      Flagun
      I ‘ve noticed there is a new module to read sensors’ states on the MM. (Big thanks to aserramonner for creating it)
      I installed it but I couldn’t read the data from the HA as there was no option in the config to provide api_password.
      I did some reasearch to make the module work. So if you still want to use it you must:
      Go to your module location open node_helper.s file
      change these lines:
      var url = config.host + ':' + config.port + '/api/states/' + devicename;
      to:
      var url = config.host + ':' + config.port + '/api/states/' + devicename + '?api_password=yourpassword';
      and these:
      var url = config.host + ':' + config.port + '/api/services/' + domain + '/' + service;
      to:
      var url = config.host + ':' + config.port + '/api/services/' + domain + '/' + service + '?api_password=yourpassword';
      I hope it helps everyone cheers!
      idoodlerI 1 Reply Last reply
      • idoodlerI
        idoodler Module Developer @Flagun
        @flagun I would recommend you to create a pull request on GitHub.
