This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
Solved MMM-hass
I ‘ve noticed there is a new module to read sensors’ states on the MM. (Big thanks to aserramonner for creating it)
I installed it but I couldn’t read the data from the HA as there was no option in the config to provide api_password.I did some reasearch to make the module work. So if you still want to use it you must:
Go to your module location open node_helper.s file
change these lines:
var url = config.host + ':' + config.port + '/api/states/' + devicename;
to:
var url = config.host + ':' + config.port + '/api/states/' + devicename + '?api_password=yourpassword';
and these:
var url = config.host + ':' + config.port + '/api/services/' + domain + '/' + service;
to:
var url = config.host + ':' + config.port + '/api/services/' + domain + '/' + service + '?api_password=yourpassword';
I hope it helps everyone cheers!
@flagun I would recommend you to create a pull request on GitHub.
