    MM Shows a plain Black Screen on iOS 9.3.5 device
    29 Posts 12 Posters 13.2k Views 11 Watching
    • idoodlerI Offline
      idoodler Module Developer
      Lol. This issue has already been fixed on the 8th of April 2018 by Chris Pickett. It is available on the develop branch. It eventually will be merged with the masterbranch.
      • P Offline
        Pipe-line
        @idoodler thanks! I will try develop branch this night :)
        • T Offline
          thobach
          I also identified the issue. It is related to the use of Promises, a feature of ECMAScript 6, which is not supported by iOS 9.3.5. The feature is used in multiple javascript files that are built into the core of MagicMirror2. I believe it can be fixed with a polyfill.
          idoodlerI 1 Reply Last reply Reply Quote 0
          • idoodlerI Offline
            idoodler Module Developer @thobach
            @thobach I don‘t think its an issue with the promise itself, but rather with the arrow (=>) operator that defines the callback.
            • T Offline
              thobach @idoodler
              @idoodler True! It was fixed in https://github.com/MichMich/MagicMirror/commit/6bb4db38428af7ac46a6f4240ab9cfe4bf9fcbea and I can load now the default configuration on iOS 9.3.5 again.
              But I can still find one use of “=>” in the develop branch: https://github.com/MichMich/MagicMirror/blob/fb0cc61e09542533affa92b1e8bd6f9a2aca6363/js/module.js#L84.
              • idoodlerI Offline
                @thobach that link you posted points me to a specific commit. I can not find any use of the => operator in the browser part In remote/develop
                  shiroe @idoodler
                  @idoodler so just to clarify, this has been found and due to be fixed?
                  or did i totally misread that…
                  if so can’t wait for new release!
                  EDIT: pardon my manners, thank you for checking this out as well :)
                  • idoodlerI Offline
                    idoodler Module Developer @shiroe
                    @shiroe This issue has already been fixed on the active development branch. Its basically ready and will be available on the next release.
                    You can already test this fix by switching to the develop branch, but be carefull, this branch is still under active development, hence the name;)
                      shiroe @idoodler
                      @idoodler thank you very much again, will keep an eager eye out for this one!
                        realthinx
                        I had also an issue with the default calendar module on an iOS 9.3.5 iPad. It could not be rendered. On debugging the iPad Safari with my MacBook i found the reason here: modules/default/calendar/calendar.js, Line 439.
                        for(let evt of eventList){
                        should be
                        for(var evt of eventList){
                        so that older browsers can render the module without error. Would be great if you can add that for the next release :folded_hands:
                        • 2 / 3
