    MM Shows a plain Black Screen on iOS 9.3.5 device
    29 Posts 12 Posters 13.2k Views 11 Watching
      StevenSeagal
      Force close the app. Then upgrade your app may solve iPad screen black problem.
      1 Reply Last reply Reply Quote -1
        spoonek
        This is still an issue.
        I have MM 2.12.0 and an iPad2 running 9.3.6 (the highest it will update to). The iPad2 gets the black screen when I go to MM http://ip-address:8080. My iphone 7 renders the page perfectly as do all of my Mac and PC laptops. I had an issue on an older laptop but updated the browser and that fixed it. I can’t update the browser on the iPad as the newer versions need iOS 10+. Any suggestions? Thanks!!
          sdetweil @spoonek
          @spoonek did u try chrome browser on the iPad?
            spoonek @sdetweil
            @sdetweil Yes, that is my default browser. I tried Safari as well, no luck. I then tried to install Firefox and got the same issue, needs version 10+. Thanks!! :clinking_beer_mugs:
              sdetweil @spoonek
              @spoonek if u have the black screen using chrome, open the dev window (see the menu) and select the console tab and scroll up to see any errors
              • C Offline
                cony
                I guess this is the problem of iOS.
                Have you tried to update the iOS and the app? May be these will help:
                1.Update the iOS and the app to the latest version
                2. Force Restart iPhone to Fix iPhone
                3. Use iOS System Recovery to [fix iOS system free for mac](link url=“https://www.tuneskit.com/ios-system-recovery-for-mac.html”)
                4. Using iTunes to Fix
                • ? Offline
                  A Former User
                  This post is deleted!
                    magicx
                    Any news here for a workaround? Tried it with my iPad 2 (9.3.6) and different browsers… also installed the developer branch on my server.
                      sdetweil @magicx
                      @magicx no, and it will be harder in 2.15, as more code has been converted to es6 notation which the early ios browsers don’t support
                      • 3 / 3
