    MagicMirror stays black, but loading from another browser (Windows, Android) works
    16 Posts 5 Posters 8.2k Views 4 Watching
      AnduriI
      Hey there,
      up to yesterday my mirror worked fine. I did install a few modules (to name them MMM-Remote-Control and MMM-forecast-io) and prepared to install facial recognition. For this last point I followed the instructions on github MMM-Facial-Recognition-OCV3. I did the following:
      sudo apt-get update
      sudo apt-get upgrade
      sudo rpi-update
      sudo reboot
      sudo apt-get install build-essential git cmake pkg-config
      sudo apt-get install libjpeg-dev libtiff5-dev libjasper-dev libpng12-dev
      sudo apt-get install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev
      sudo apt-get install libxvidcore-dev libx264-dev
      sudo apt-get install libgtk2.0-dev
      sudo apt-get install libatlas-base-dev gfortran
      cd ~
      git clone https://github.com/Itseez/opencv.git
      cd opencv
      git checkout 3.3.0
      cd ~
      git clone https://github.com/Itseez/opencv_contrib.git
      cd opencv_contrib
      git checkout 3.3.0
      wget https://bootstrap.pypa.io/get-pip.py
      sudo apt-get install python3-dev
      sudo python3 get-pip.py
      I did not yet started building OpenCV. After that I noticed my mirror turned black (didn’t checked inbetween these steps). Just to check I disabled the modules installed since last known working condition, but without success. I only checked the modules after installing from both my Windows pc and my smartphone. That worked fine at all times.
      My suspicion is that the updating in the beginning of MMM-Facial-Recognition-OCV3 did break something.
      I tried npm install electron@1.4.15 and checked the logs, but there is no entry. My node is version 6.14.2 and npm is 3.10.10
      Can anyone give me a hint on what to check for?
      Best regards,
      Anduril
        sdetweil
        I had to uninstall electron and install version 1.7.9 to get rid of the blank screen
          AnduriI
          what do you mean with uninstall? I did remove ~/MagicMirror/node_modules/electron and reinstalled via npm install in the MagicMirror folder. But still black screen.
            sdetweil @AnduriI
            @andurii npm has a remove operation
            npm remove electron
            npm install electron@1.7.9
              AnduriI
              ok I did use npm remove, but on installing electron@1.7.9 I got this:
              pi@Spieglein:~/MagicMirror $ npm install electron@1.7.9
              > electron@1.7.9 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              events.js:160
                    throw er; // Unhandled 'error' event
              Error: EIO: i/o error, read
                  at Error (native)
              npm ERR! Linux 4.14.44-v7+
              npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "electron@1.7.9"
              npm ERR! node v6.14.2
              npm ERR! npm  v3.10.10
              npm ERR! code ELIFECYCLE
              npm ERR! electron@1.7.9 postinstall: `node install.js`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the electron@1.7.9 postinstall script 'node install.js'.
              npm ERR! If you do, this is most likely a problem with the electron package,
              npm ERR! not with npm itself.
              npm ERR!     node install.js
              npm ERR!     npm bugs electron
              npm ERR! Or if that isn't available, you can get their info via:
              npm ERR!     npm owner ls electron
              I tried to use only npm install and see what version it installes:
              > electron@1.8.7 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              > magicmirror@2.3.1 install /home/pi/MagicMirror
              > cd vendor && yon install
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              > magicmirror@2.3.1 postinstall /home/pi/MagicMirror
              > sh installers/postinstall/postinstall.sh && yon run install-fonts
              MagicMirror installation successful!
              > magicmirror@2.3.1 install-fonts /home/pi/MagicMirror
              > cd fonts && yon install
              magicmirror@2.3.1 /home/pi/MagicMirror
              └─┬ electron@1.8.7
                ├── @types/node@8.10.19
                └─┬ electron-download@3.3.0
                  ├─┬ fs-extra@0.30.0
                  │ └── klaw@1.3.1
                  ├── home-path@1.0.6
                  └─┬ sumchecker@1.3.1
                    └── es6-promise@4.2.4
              So version 1.8.7 installes without problem but doesn’t work. Any further ideas?
                abetterway @AnduriI
                @andurii,
                I ended up installing Chromium and displaying the Mirror locally using that. That was the only way I could get past the black screen.
                Kyle
                  AnduriI
                  ok, I found a simply way to make chromium start in full screen mode, but how do I have to disable electron from entering full screen?
                    AnduriI
                    well that didn’t worked. I still only see a black monitor. I did also reinstall MagicMirror and connected to it via VNC. Strange thing is that I can see my MM on my VNC client, but not on my monitor. I didn’t even thought this would be possible…
                    A SnilleS idoodlerI 3 Replies Last reply Reply Quote 0
                      abetterway @AnduriI
                      @andurii, I have no idea then. It worked perfectly for me. I’ll have to take a look at my configuration and let you know. I am currently traveling so I can’t look at the moment.
                      • SnilleS Offline
                        Snille Module Developer @AnduriI
                        @andurii Hmm… Sounds like your monitor has gone to standby.
                        Login via SSH:
                        Make a sh file named: monitor.sh
                        Add the flowing to the file:
                        #!/bin/bash
                        if [ "$1" == 'on' ]; then
                          tvservice -p;
                          chvt 6;
                          chvt 7;
                        fi
                        if [ "$1" == 'off' ]; then
                          tvservice -o
                        fi
                        Then make it executable with: chmod +x monitor.sh
                        Turn on them monitor it like this: ./monitor.sh on
                        Turn it off like this: ./monitor.sh off
                        And of course, make sure you are on the correct input to actually see the Pi… :)
                        That should “turn on” (or off) the screen from SSH. :)
                        If you cant find it, make it and share it
                        MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                          AnduriI
                          trying your script or chvt 6 [or 7] manually does result in this error:
                          Konnte keinen Dateideskriptor finden, der auf die Konsole verweist.
                          The monitor is turning on correctly and I can see the background dark grey in the mirror, but it simply does not show the mirror. Maybe it somehow has multiple desktops defined and just showing the wrong on hdmi output…
                          SnilleS 1 Reply Last reply Reply Quote 0
                          • idoodlerI Offline
                            idoodler Module Developer @AnduriI
                            @andurii Yep, that definetly sounds like your monitor just went sleeping.
                            • SnilleS Offline
                              @andurii I get the same error message “Couldn’t get a file descriptor referring to the console” but the monitor turn on… :)
                              I have tow desktops as well, the Mirror shows up on one of them… I can use (in VNC) CTRL + ALT + Right or Left arrow key to switch between virtual desktops.
                                sdetweil
                                that only works for PI devices where tvservice command exists… I run MM on an ODROID so, that doesn’t help…
                                I also use an EnergyStar TV, which freaks out when the video input signal is cut and then powers off after 15 minutes…
                                  AnduriI
                                  I did use CTRL + ALT + RIGHT or LEFT, but that didn’t helped either. Only change was that in the middle of the VNC-session was a small blue notification saying Desktop 1 so I suppose I have only one virtual desktop active.
                                    AnduriI
                                    well something strange I noticed… (don’t know if that’s related)
                                    My Desktop used to be PIXEL I think (this nice road wallpaper and menu bars at the top. Now it looks like it is running Openbox. I don’t know how this happened, but it was not intended by me. Was that changed in the newest version because of my upgrades?
