    MMM-SleepWake using external motion detection source
    16 Posts 4 Posters 9.4k Views 4 Watching
      mithatcak
      @sdetweil I noticed a weird issue. sometimes after several sleep&wake cycles, when it goes to sleep only the stock currentweather and weatherforecast modules stays on. there is no error in the motion.log or MM log.
      here is my config, I was using delay: 5 then switched to 0.2 so I can repeat the issue faster.
      			module: "MMM-SleepWake",
      			config:{
      				delay:  0.2,               // default
      				source: "external",
      				mode:  "HIDE"
      			 // detectionDir: folder containing externally generated file when motion starts
      			 //               will be created if needed
      			 // detectionFile:  filename generated for motion start. default = 'detected'
        sdetweil @mithatcak
        @mithatcak very interesting… I use those default modules too and I have never seen that behavior.
        like they didn’t handle the suspend request…
        i have 4 systems running this everyday for months… only see the updatenotification module output on one as it doesn’t handle hide/suspend…
        i will do some additional debugging
          sdetweil @mithatcak
          @mithatcak could you try something for me
          i cannot reproduce this on any of my systems…
          edit the MMM-SleepWake.js file
          		case "SLEEP_HIDE":
          			MM.getModules().enumerate((module) => {
          				// if the module is already hidden
          				if(module.hidden==true)
          					// save it for wake up
          					{v_self1.previously_hidden.push(module.identifier);}
          				else
          					// hide this module
          					{module.hide(1000);}   // < --- change this line , remove the 1000
          should look like this
          		case "SLEEP_HIDE":
          				else
          					// hide this module
          					{module.hide();}
          let me know
            mithatcak @sdetweil
            @sdetweil Unfortunately same result :/ I will try to replace currentweather and weatherforecast with weather module and see if it’s going to make any difference.
              mithatcak
              @sdetweil Good news, switching to new weather module fixed the issue.
                sdetweil @mithatcak
                @mithatcak interesting
