    MMM-SleepWake using external motion detection source
    16 Posts 4 Posters 10.6k Views 4 Watching
    • E Offline
      elleclouds @sdetweil
      @sdetweil Can this script be used with a raspberry pi camera? I want my mirror to wake and sleep upon detection from camera. It there a step by step for a noob as myself?
        sdetweil @elleclouds
        @elleclouds I didn’t want to learn all about cameras, or be on the hook for continuing configuration options for cameras… and I found this code that handles all that AND signals motion
        https://motion-project.github.io/
        on its configuration page its says
        Determine the type of camera
        v4l2 devices which are most webcams
        Composite capture cards
        Network or IP cameras
        The PI camera
        Static movie files.
        it documents using the Raspberry Pi camera
        Raspberry Pi cameras can be set up two different ways. If Motion is installed by using the apt packages (e.g. apt-get install motion), then the camera must be set up using the bcm2835-v4l2 module which creates a v4l2 device for the camera. Users will need to install this module using the command sudo modprobe bcm2835-v4l2. This will set up the camera as a normal v4l2 device and it can be accessed via a standard /dev/videoX device. If Motion is built from source or installed via the deb packages on the project release page, then an additional option is to set up the camera using the mmalcam_name parameter or using the bcm2835-v4l2 module. When Motion is installed via apt, the mmalcam option is not available.
        Motion project can also record images on motion, movies, etc,etc,etc,etc,
        • E Offline
          elleclouds
          I am a noobie, but I feel like I followed most of the instructions I’ve found online on how to get this to work, but I’m still having some issues of actually getting the mirror to turn of or on. I keep getting the error in terminal when I run motion : vid_v4lx_start: Failed to open video device /dev/video: No such file directory.
          I’d greatly appreciate a video or help with set up… A youtube video would save me time and troubleshooting something that may be simple.
            @elleclouds ok…
            the motion module needs a video device…
            run these two commands
            sudo apt-get install v4l-utils
            v4l2-ctl --list-devices
            find the ‘camera’ device in the list
            mine shows
            odroid@odroid:~/MagicMirror$ v4l2-ctl --list-devices
            s5p-mfc-dec (platform:11000000.codec):
                    /dev/video10
                    /dev/video11
            s5p-jpeg encoder (platform:11f50000.jpeg):
                    /dev/video30
                    /dev/video31
            s5p-jpeg encoder (platform:11f60000.jpeg):
                    /dev/video32
                    /dev/video33
            exynos-gsc gscaler (platform:13e00000.video-scaler):
                    /dev/video20
            exynos-gsc gscaler (platform:13e10000.video-scaler):
                    /dev/video21
            UVC Camera (046d:0825) (usb-xhci-hcd.3.auto-1.2):
                    /dev/video0
            the last is the camera…
            so, in the motion.conf,
            set the line videodevice to the value returned for the camera, in my case /dev/video0
            # Videodevice to be used for capturing  (default /dev/video0)
            # for FreeBSD default is /dev/bktr0
            videodevice  /dev/video0
            after changing the config file
            either do
            ps -ef | grep motion
                 get the process id (pid) use below
            kill -s SIGHUP pid
            mine is
            odroid@odroid:~/MagicMirror$ ps -ef | grep motion
            root      7756     1  0 Mar08 ?        00:14:21 motion
            pid = 7756
            or reboot
              mithatcak
              this is exactly what I need. works perfect! just hiding modules and no more ugly “NO SIGNAL” message floating on my mirror. Thank you!
                sdetweil @mithatcak
                @mithatcak glad its working !.. i use it everyday on multiple mirrors…
                  mithatcak
                  @sdetweil I noticed a weird issue. sometimes after several sleep&wake cycles, when it goes to sleep only the stock currentweather and weatherforecast modules stays on. there is no error in the motion.log or MM log.
                  here is my config, I was using delay: 5 then switched to 0.2 so I can repeat the issue faster.
                  			module: "MMM-SleepWake",
                  			config:{
                  				delay:  0.2,               // default
                  				source: "external",
                  				mode:  "HIDE"
                  			 // detectionDir: folder containing externally generated file when motion starts
                  			 //               will be created if needed
                  			 // detectionFile:  filename generated for motion start. default = 'detected'
                    sdetweil @mithatcak
                    @mithatcak very interesting… I use those default modules too and I have never seen that behavior.
                    like they didn’t handle the suspend request…
                    i have 4 systems running this everyday for months… only see the updatenotification module output on one as it doesn’t handle hide/suspend…
                    i will do some additional debugging
                      sdetweil @mithatcak
                      @mithatcak could you try something for me
                      i cannot reproduce this on any of my systems…
                      edit the MMM-SleepWake.js file
                      		case "SLEEP_HIDE":
                      			MM.getModules().enumerate((module) => {
                      				// if the module is already hidden
                      				if(module.hidden==true)
                      					// save it for wake up
                      					{v_self1.previously_hidden.push(module.identifier);}
                      				else
                      					// hide this module
                      					{module.hide(1000);}   // < --- change this line , remove the 1000
                      should look like this
                      		case "SLEEP_HIDE":
                      				else
                      					// hide this module
                      					{module.hide();}
                      let me know
                        mithatcak @sdetweil
                        @sdetweil Unfortunately same result :/ I will try to replace currentweather and weatherforecast with weather module and see if it’s going to make any difference.
                          mithatcak
                          @sdetweil Good news, switching to new weather module fixed the issue.
                            sdetweil @mithatcak
                            @mithatcak interesting
