MMM-SleepWake using external motion detection source
16 Posts 4 Posters 7.6k Views 4 Watching
    Description
    Enable MagicMirror sleep from external (camera) sources
    If you are running the MM on a non PI device, or want to control sleep/wake without having to wire up another device, this module will take external info and signal MM to sleep or wake up.
    I use a Webcam camera for the motion detection, driven by the github Motion project.
    That project allows for a script to be run when motion starts and ends. I provide a script that
    creates a file for both events, and the module detects those files.
    the module supports sleep and wake 3 different ways… On PI using the tvservice command, or the exec dpms command if not using HDMI, or hiding all modules if using an energystar monitor (like my tv)
    I have submitted changes to MMM-voice and HelloLucy to allow our modules to know about the others processing… so voice Go To Sleep and motion wakeup work… if using the Hide method, modules already hidden at sleep will remain hidden on wakeup.
    Download:
    [card:sdetweil/MMM-SleepWake]
    Version 1.0
    M 1 Reply Last reply Jun 24, 2018, 12:28 AM Reply Quote 3
      Well done, sir!
      • E Offline
        elleclouds
        Can this use a Nest Smoke Detector’s motion detecting as a trigger to activate SleepWake?
        S 1 Reply Last reply Feb 24, 2019, 5:35 PM Reply Quote 0
          sdetweil @elleclouds
          @elleclouds I do not know. Is there a nest API the reports motion?
          I have not found the same for my ecobee room sensors
          If u can find the API, just call my little shell script to report start and end of movement
          E 1 Reply Last reply Feb 25, 2019, 3:45 PM Reply Quote 0
          • E Offline
            elleclouds @sdetweil
            @sdetweil Can this script be used with a raspberry pi camera? I want my mirror to wake and sleep upon detection from camera. It there a step by step for a noob as myself?
            S 1 Reply Last reply Feb 26, 2019, 1:26 PM Reply Quote 0
              @elleclouds I didn’t want to learn all about cameras, or be on the hook for continuing configuration options for cameras… and I found this code that handles all that AND signals motion
              https://motion-project.github.io/
              on its configuration page its says
              Determine the type of camera
              v4l2 devices which are most webcams
              Composite capture cards
              Network or IP cameras
              The PI camera
              Static movie files.
              it documents using the Raspberry Pi camera
              Raspberry Pi cameras can be set up two different ways. If Motion is installed by using the apt packages (e.g. apt-get install motion), then the camera must be set up using the bcm2835-v4l2 module which creates a v4l2 device for the camera. Users will need to install this module using the command sudo modprobe bcm2835-v4l2. This will set up the camera as a normal v4l2 device and it can be accessed via a standard /dev/videoX device. If Motion is built from source or installed via the deb packages on the project release page, then an additional option is to set up the camera using the mmalcam_name parameter or using the bcm2835-v4l2 module. When Motion is installed via apt, the mmalcam option is not available.
              Motion project can also record images on motion, movies, etc,etc,etc,etc,
              • E Offline
                elleclouds
                I am a noobie, but I feel like I followed most of the instructions I’ve found online on how to get this to work, but I’m still having some issues of actually getting the mirror to turn of or on. I keep getting the error in terminal when I run motion : vid_v4lx_start: Failed to open video device /dev/video: No such file directory.
                I’d greatly appreciate a video or help with set up… A youtube video would save me time and troubleshooting something that may be simple.
                S 1 Reply Last reply Mar 11, 2019, 2:28 AM Reply Quote 0
                  @elleclouds ok…
                  the motion module needs a video device…
                  run these two commands
                  sudo apt-get install v4l-utils
                  v4l2-ctl --list-devices
                  find the ‘camera’ device in the list
                  mine shows
                  odroid@odroid:~/MagicMirror$ v4l2-ctl --list-devices
                  s5p-mfc-dec (platform:11000000.codec):
                          /dev/video10
                          /dev/video11
                  s5p-jpeg encoder (platform:11f50000.jpeg):
                          /dev/video30
                          /dev/video31
                  s5p-jpeg encoder (platform:11f60000.jpeg):
                          /dev/video32
                          /dev/video33
                  exynos-gsc gscaler (platform:13e00000.video-scaler):
                          /dev/video20
                  exynos-gsc gscaler (platform:13e10000.video-scaler):
                          /dev/video21
                  UVC Camera (046d:0825) (usb-xhci-hcd.3.auto-1.2):
                          /dev/video0
                  the last is the camera…
                  so, in the motion.conf,
                  set the line videodevice to the value returned for the camera, in my case /dev/video0
                  # Videodevice to be used for capturing  (default /dev/video0)
                  # for FreeBSD default is /dev/bktr0
                  videodevice  /dev/video0
                  after changing the config file
                  either do
                  ps -ef | grep motion
                       get the process id (pid) use below
                  kill -s SIGHUP pid
                  mine is
                  odroid@odroid:~/MagicMirror$ ps -ef | grep motion
                  root      7756     1  0 Mar08 ?        00:14:21 motion
                  pid = 7756
                  or reboot
                    mithatcak
                    this is exactly what I need. works perfect! just hiding modules and no more ugly “NO SIGNAL” message floating on my mirror. Thank you!
                    S 1 Reply Last reply Aug 20, 2019, 2:47 PM Reply Quote 0
                      sdetweil @mithatcak
                      @mithatcak glad its working !.. i use it everyday on multiple mirrors…
