    MMM-SleepWake using external motion detection source
    16 Posts 4 Posters 9.4k Views 4 Watching
      sdetweil @elleclouds
      @elleclouds ok…
      the motion module needs a video device…
      run these two commands
      sudo apt-get install v4l-utils
      v4l2-ctl --list-devices
      find the ‘camera’ device in the list
      mine shows
      odroid@odroid:~/MagicMirror$ v4l2-ctl --list-devices
      s5p-mfc-dec (platform:11000000.codec):
              /dev/video10
              /dev/video11
      s5p-jpeg encoder (platform:11f50000.jpeg):
              /dev/video30
              /dev/video31
      s5p-jpeg encoder (platform:11f60000.jpeg):
              /dev/video32
              /dev/video33
      exynos-gsc gscaler (platform:13e00000.video-scaler):
              /dev/video20
      exynos-gsc gscaler (platform:13e10000.video-scaler):
              /dev/video21
      UVC Camera (046d:0825) (usb-xhci-hcd.3.auto-1.2):
              /dev/video0
      the last is the camera…
      so, in the motion.conf,
      set the line videodevice to the value returned for the camera, in my case /dev/video0
      # Videodevice to be used for capturing  (default /dev/video0)
      # for FreeBSD default is /dev/bktr0
      videodevice  /dev/video0
      after changing the config file
      either do
      ps -ef | grep motion
           get the process id (pid) use below
      kill -s SIGHUP pid
      mine is
      odroid@odroid:~/MagicMirror$ ps -ef | grep motion
      root      7756     1  0 Mar08 ?        00:14:21 motion
      pid = 7756
      or reboot
        mithatcak
        this is exactly what I need. works perfect! just hiding modules and no more ugly “NO SIGNAL” message floating on my mirror. Thank you!
          sdetweil @mithatcak
          @mithatcak glad its working !.. i use it everyday on multiple mirrors…
            mithatcak
            @sdetweil I noticed a weird issue. sometimes after several sleep&wake cycles, when it goes to sleep only the stock currentweather and weatherforecast modules stays on. there is no error in the motion.log or MM log.
            here is my config, I was using delay: 5 then switched to 0.2 so I can repeat the issue faster.
            			module: "MMM-SleepWake",
            			config:{
            				delay:  0.2,               // default
            				source: "external",
            				mode:  "HIDE"
            			 // detectionDir: folder containing externally generated file when motion starts
            			 //               will be created if needed
            			 // detectionFile:  filename generated for motion start. default = 'detected'
              sdetweil @mithatcak
              @mithatcak very interesting… I use those default modules too and I have never seen that behavior.
              like they didn’t handle the suspend request…
              i have 4 systems running this everyday for months… only see the updatenotification module output on one as it doesn’t handle hide/suspend…
              i will do some additional debugging
                sdetweil @mithatcak
                @mithatcak could you try something for me
                i cannot reproduce this on any of my systems…
                edit the MMM-SleepWake.js file
                		case "SLEEP_HIDE":
                			MM.getModules().enumerate((module) => {
                				// if the module is already hidden
                				if(module.hidden==true)
                					// save it for wake up
                					{v_self1.previously_hidden.push(module.identifier);}
                				else
                					// hide this module
                					{module.hide(1000);}   // < --- change this line , remove the 1000
                should look like this
                		case "SLEEP_HIDE":
                				else
                					// hide this module
                					{module.hide();}
                let me know
                  mithatcak @sdetweil
                  @sdetweil Unfortunately same result :/ I will try to replace currentweather and weatherforecast with weather module and see if it’s going to make any difference.
                    mithatcak
                    @sdetweil Good news, switching to new weather module fixed the issue.
                      sdetweil @mithatcak
                      @mithatcak interesting
