    Where to get (cheap) acrylic mirror from in Germany
    56 Posts 16 Posters 86.4k Views 18 Watching
    • C Offline
      compoti
      The Mirror from glas-per-klick looks very cool and the price is not so bad, but they don’t cut the Mirror to my needed size? I’m right or oversee something?
      I have tested my MM with a selfmade Mirror from Plexiglass and Mirror Foil, but it looks very poorly. Now I need a real Mirror. The MagicMirror is a neverending project, i spent so much time to wait on a Parcel Service like DHL, UPS, Amazon Logistics and so on :-D
        dbahn25 @compoti
        @compoti said in Where to get (cheap) acrylic mirror from in Germany:
        I don’t think you’re overseeing anything. You should probably write to them to ask if they have any other sizes (but I think generally, 60x40cm is quite a good size for a MM).
        I tested the glas-per-klick mirror with MM and a Pi 2. In daylight, right next to a window, it’s a bit too dark. My monitor is not really that bright, so it should be fine with a better monitor. When it’s dark and there’s only the ceiling light on (which is quite bright), the mirror’s perfectly fine to read.
          sunnysys @dbahn25
          @dbahn25 said in Where to get (cheap) acrylic mirror from in Germany:
          Hi dbahn25!
          Could you, please, take some photos in daylight? I’d like to build MM for my girlfriend, that can be used like a normal mirror in a bright room. Actually it’s more important than being smart. :)
          Thanks in advance!
          • G Offline
            Goldjunge_Chriz
            Hi folks
            I can order a very good magicmirror glass for you if you want.
            Please have a Look at my Thread https://forum.magicmirror.builders/topic/1011/two-way-mirror-order-in-germany/39
              dbahn25 @sunnysys
              @sunnysys said in Where to get (cheap) acrylic mirror from in Germany:
              Hi dbahn25!
              Thanks in advance!
              It’s really, really clear. But see yourself :)
              • G Offline
                Gubert
                Hey guys,
                im new here and from germany.
                Any new suggestions here? i definitely need an special size so for my spyglas.
                Where do you actualy buy your mirror? Any other suggestions as myspiegel.de where the only offer 8mm thick mirrors?
                https://www.myspiegel.de/spionspiegel-pg-2102.html
                • 6
                • 6 / 6
