    config file issue
    2 Posts 2 Posters 844 Views 2 Watching
    • O Offline
      oj96
      when magic mirror loads it displays config file issue, when i remove the wunderlist code it stops and run fine. can anyone point out the issue
      please```
      //modules: [
      module: ‘MMM-Wunderlist’,
      position: ‘top_right’, // This can be any of the regions. Best results in left or right regions.
      header: ‘UPCOMING REMINDERS’, // This is optional
      clientID: ‘xxxxxxxxxxxxxx’,
      accessToken: ‘xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx’
      lists: [ “inbox”],
      interval: 60
      fade: true
      module: “alert”,
      module: “updatenotification”,
      position: “top_bar”
      module: “clock”,
      position: “top_left”
      module: “calendar”,
      header: “UK Holidays”,
      position: “top_left”,
      symbol: "calendar-check-o ",
      url: “webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics”
      module: “compliments”,
      position: “lower_third”
      module: “currentweather”,
      position: “top_right”,
      locationID: “”, //ID from http://www.openweathermap.org/help/city_list.txt
      appid: “YOUR_OPENWEATHER_API_KEY”
      module: “weatherforecast”,
      header: “Weather Forecast”,
      locationID: “5128581”, //ID from http://www.openweathermap.org/help/city_list.txt
      module: “newsfeed”,
      position: “bottom_bar”,
      feeds: [
      title: “Threatpost”,
      url: “https://threatpost.com/feed/”
      showSourceTitle: true,
      showPublishDate: true
        sdetweil
        @oj96 said in config file issue:
        lists: [ “inbox”],
        interval: 60
        fade: true
        well, a bunch of problems…
        1 you have the wrong single and double quotes here… do NOT use a word processing editor… only a text editor… (nano or gedit or vi)…
        2. missing comma after accesstoken line and interval line
        and u have two modules: [ blocks…
        quick way to test your config for syntax… copy/paste it all to jslint.com
        check long lines, single quotes, and whitespace mess at the bottom, then press jslint
        then copy/paste it back to the config.js file.
