    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 124.7k Views 16 Watching
      MarkAlisch @KirAsh4
      Hello,
      Gotcha!
      I got it running: D
      The difference to the 20 previous try was that I did not make the whole in the pure console, but in a terminal under the graphical surface.
      This can also be seen in the instructions under the URL https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6
      • C Offline
        cpramhofer
        Hi All,
        after my holiday i gave the thing another chance with a fresh install:
        Raspbian Jessie with Pixel
        2016-09-23
        (is this the problem???)
        npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
        npm ERR! Linux 4.4.21-v7+
        npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
        npm ERR! node v6.9.1
        npm ERR! npm v3.10.8
        npm ERR! code ELIFECYCLE
        npm ERR! electron-prebuilt@1.3.9 postinstall: node install.js
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the electron-prebuilt@1.3.9 postinstall script ‘node install.js’.
        npm ERR! If you do, this is most likely a problem with the electron-prebuilt package,
        npm ERR! not with npm itself.
        npm ERR! node install.js
        npm ERR! npm bugs electron-prebuilt
        npm ERR! Or if that isn’t available, you can get their info via:
        npm ERR! npm owner ls electron-prebuilt
        npm ERR! /root/MagicMirror/npm-debug.log
        or is it the problem that the installer is still using eletron-prebuild instead of electron??
        • T Offline
          tajno
          Did you tried the followed:
          npm install npm@latest -g
          npm install -g grunt
          npm install -g electron
          • C Offline
            cpramhofer
            IT WORKS!!
            thanks @tajno for the hint!
            My Steps to working MM:
            • Fresh Card with latest Version of Raspian (PIXEL)
            • [running the installer Script]
            • MMM DID NOT WORK AT THIS STAGE
            • running
              sudo npm install npm@latest -g
              sudo npm install -g grunt
              sudo npm install -g electron
            • manual install of MMM (git clone / sudo npm install / npm start)
            kind regards
            Christoph
            • SharkbyteS Offline
              Sharkbyte
              here is what worked for me
              git reset --hard and then git pull && npm install
              Technically challenged all day everyday.
              So then I just go here Evolution MMA
              Of course though spending time with the son is always the best of the best!
                sdetweil @Sharkbyte
                @sharkbyte yeh, if you use my upgrade script it handles all that. Reset hard is, in my opinion, a bad thing to do, unless you KNOW why you are doing it.
                see
                • 4 / 4
